Skip to main content
Programming Techniques
This section discusses programming techniques and issues that go beyond the basics of the Igor programming language and which all Igor programmers should understand. Techniques for advanced programmers are discussed under Advanced Topics.
The Include Statement​
The include statement is a compiler directive that you can put in your procedure file to tell Igor to open another procedure file. A typical include statement looks like this:
#include <Split Axis>
This statement tells Igor to open the file "Split Axis.ipf" in the WaveMetrics Procedures folder. Once this statement has been compiled, you can call routines from that file. This is the recommended way to access procedure files that contain utility routines.
The # character at the beginning tells Igor that a compiler directive follows. Compiler directives, except for conditional compilation directives, must start at the far left edge of the procedure window with no leading tabs or spaces. Include statements can appear anywhere in the file but it is conventional to put them near the top.
It is possible to include a file which in turn includes other files. Igor opens all of the included files.
Igor opens included files when it compiles the procedures. If you remove an include statement from a procedure file, Igor automatically closes the file on the next compile.
There are four forms of the include statement:
  1. Igor searches for the named file in "Igor Pro Folder/WaveMetrics Procedures" and in any subfolders:
    #include <fileName>
    Example: #include <Split Axis>
  2. Igor searches for the named file in "Igor Pro Folder/User Procedures" and "Igor Pro User Files/User Procedures" and in any subfolders:
    #include "fileName"
    Example: #include "Utility Procs"
  3. Igor looks for the file only in the exact location specified:
    #include "full file path"
    Example: #include "Hard Disk:Procedures:Utility Procs"
  4. Igor looks for the file relative to the Igor Pro Folder and the Igor Pro User Files folder and the folder containing the procedure file that contains the #include statement:
    #include ":partial file path"
    Example: #include ":Spectroscopy Procedures:Voigt Procs"
    Igor looks first relative to the Igor Pro Folder. If that fails, it looks relative to the Igor Pro User Files folder. If that fails it looks relative to the procedure file containing the #include statement or, if the #include statement is in the built-in procedure window, relative to the experiment file.
    The name of the file being included must end with the standard ".ipf" extension but the extension is not used in the include statement.
Procedure File Version Information​
If you create a procedure file to be used by other Igor users, it's a good idea to add version information to the file. You do this by putting a #pragma version statement in the procedure file. For example:
#pragma version = 1.10
This statement must appear with no indentation and must appear in the first 50 lines of the file. If Igor finds no version pragma, it treats the file as version 1.00.
Igor looks for the version information when the user invokes the File Information dialog from the Procedure menu. If the file has version information, Igor displays the version next to the file name in the dialog.
Igor also looks for version information when it opens an included file. An include statement can require a certain version of the included file using the following syntax:
#include <Bivariate Histogram> version>=1.02
If the required version of the procedure file is not available, Igor displays a warning to inform the user that the procedure file needs to be updated.
In Igor Pro 9.01 and later, you can programmatically determine the procedure file's version using the ProcedureVersion function.
Turning the Included File's Menus Off​
Normally an included procedure file's menus and menu items are displayed. However, if you are including a file merely to call one of its procedures, you may not want that file's menu items to appear. To suppress the file's menus and menu items, use:
#include <Decimation> menus=0
To use both the menus and version options, you must separate them with a comma:
#include <Decimation> menus=0, version>=1.1
Optionally Including Files​
Compilation usually ceases and returns an error if the included file isn't found. On occasion it is advantageous to allow compilation to proceed if an included file isn't present or is the wrong version. Optionally including a procedure file is appropriate only if the file truly isn't needed to make procedures compile or operate.
Use the "optional" keyword to optionally include a procedure file:
#include <Decimation> version>=1.1, optional
Writing General-Purpose Procedures​
Procedures can be placed on a scale ranging from general to specific. Usually, the high-level procedures of a program are specific to the task at hand and call on more general, lower-level procedures. The most general procedures are often called "utility" procedures.
You can achieve a high degree of productivity by building a library of utility procedures that you reuse in different programs. In Igor, you can think of the routines in an experiment's built-in Procedure window as a program. It can call utility routines which should be stored in a separate procedure file so that they are available to multiple experiments.
The files stored in the WaveMetrics Procedures folder contain general-purpose procedures on which your high-level procedures can build. Use the include statement (See The Include Statement) to access these and other utility files.
When you write utility routines, you should keep them as general as possible so that they can be reused as much as possible. Here are some guidelines.
  • Avoid the use of global variables as inputs or outputs. Using globals hard-wires the routine to specific names which makes it difficult to use and limits its generality.
  • If you use globals to store state information between invocations of a routine, package the globals in data folders.
    WaveMetrics packages usually create data folders inside "root:Packages". We use the prefix "WM" for data folder names to avoid conflict with other packages. Follow this lead and should pick your own data folder names so as to minimize the chance of conflict with WaveMetrics packages or with others. See Managing Package Data for details.
  • Choose a clear and specific name for your utility routine.
    By choosing a name that says precisely what your utility routine does, you minimize the likelihood of collision with the name of another procedure. You also increase the readability of your program.
  • Make functions which are used only internally by your procedures static.
    By making internal functions static (i.e., private), you minimize the likelihood of collision with the name of another procedure.
Programming with Liberal Names​
Standard names in Igor can contain letters, numbers and the underscore character only.
It is possible to use wave names and data folder names that contain almost any character. Such names are called "liberal names" (see Liberal Object Names).
As this section explains, programmers need to use special techniques for their procedures to work with liberal names. Consequently, if you do use liberal names, some existing Igor procedures may break.
Whenever a liberal name is used in a command or expression, the name must be enclosed in single quotes. For example:
Make 'Wave 1', wave2, 'miles/hour'
'Wave 1' = wave2 + 'miles/hour'
Without the single quotes, Igor has no way to know where a particular name ends. This is a problem whenever Igor parses a command or statement. Igor parses commands at the following times:
  • When it compiles a user-defined function.
  • When it compiles the right-hand side of an assignment statement, including a formula (:= dependency expression).
  • When it interprets a macro.
  • When it interprets a command that you enter in the command line or via an Igor Text file.
  • When it interprets a command you submit for execution via the Execute operation.
  • When it interprets a command that an XOP submits for execution via the XOPCommand or XOPSilentCommand callback routines.
When you use an Igor dialog to generate a command, Igor automatically uses quotes where necessary.
Programmers need to be concerned about liberal names whenever they create a command and then execute it, via an Igor Text file, the Execute operation or the XOPCommand and XOPSilentCommand callback routines, and when creating a formula. In short, when you create something that Igor has to parse, names must be quoted if they are liberal. Names that are not liberal can be quoted or unquoted.
If you have a procedure that builds up a command in a string variable and then executes it via the Execute operation, you must use the PossiblyQuoteName function to provide the quotes if needed.
Here is a trivial example showing the liberal-name unaware and liberal-name aware techniques:
Function AddOneToWave(w)
WAVE w
String cmd
String name = NameOfWave(w)
// Liberal-name unaware way - generates error with liberal name
sprintf cmd, "%s += 1", name
Execute cmd
// Liberal-name aware way
sprintf cmd, "%s += 1", PossiblyQuoteName(name)
Execute cmd
Imagine that you pass a wave named "wave 1" to this function. Using the old technique, the Execute operation would see the following text:
wave 1 += 1
Igor would generate an error because it would try to find an operation, macro, function, wave or variable named "wave".
Using the new technique, the Execute operation would see the following text:
'wave 1' += 1
This works correctly because Igor sees 'wave 1' as a single name.
When you pass a string expression containing a simple name to the $ operator, the name must not be quoted because Igor does no parsing:
String name = "wave 1"; Display $name // Right
String name = "'wave 1'"; Display $name // Wrong
However, when you pass a path in a string to $, any liberal names in the path must be quoted:
String path = "root:'My Data':'wave 1'"; Display $path // Right
String path = "root:My Data:wave 1"; Display $path // Wrong
For further explanation of liberal name quoting rules, see Accessing Global Variables and Waves Using Liberal Names.
Some built-in string functions return a list of waves. WaveList is the most common example. If liberal wave names are used, you will have to be extra careful when using the list of names. For example, you can't just append the list to the name of an operation that takes a list of names and then execute the resulting string. Rather, you will have to extract each name in turn, possibly quote it and then append it to the operation.
For example, the following will work if all wave names are standard but not if any wave names are liberal:
Execute "Display " + WaveList("*", ",", "")
Now you will need a string function that extracts out each name, possibly quotes it, and creates a new string using the new names separated by commas. The PossiblyQuoteList function in the WaveMetrics procedure file Strings as Lists does this. The preceding command becomes:
Execute "Display " + PossiblyQuoteList(WaveList("*", ",", ""), ",")
To include the Strings as Lists file in your procedures, see The Include Statement.
For details on using liberal names in user-defined functions, see Accessing Global Variables and Waves Using Liberal Names.
These functions are useful for programmatically generating object names: CreateDataObjectName, CheckName, CleanupName, and UniqueName.
Programming with Data Folders​
For general information on data folders, including syntax for using data folders in command line operations, see Data Folders.
Data folders provide a powerful way to organize data and reduce clutter. However, using data folders introduces some complexity in Igor programming. The name of a variable or wave is no longer sufficient to uniquely identify it because the name alone does not indicate in which data folder it resides.
If a procedure is designed to operate on the current data folder, then it is the user's responsibility to set the current data folder correctly before running the procedure. When writing such a procedure, you can use WaveExists, NVAR_Exists and SVAR_Exists to check the existence of expected objects and fail gracefully if they do not exist.
Data Folder Applications​
There are two main uses for data folders:
  • To store globals used by procedures to keep track of their state
  • To store runs of data with identical structures
The following sections explore these applications.
Storing Procedure Globals​
If you create packages of procedures, for example data acquisition, data analysis, or a specialized plot type, you typically need to store global variables, strings and waves to maintain the state of your package. You should keep all such items in a data folder that you create with a unique name to reduce clutter and avoid conflicts with other packages.
If your package is inherently global in nature, data acquisition for example, create your data folder within a data folder named Packages that you create in the root data folder. If your package is named MyDataAcq, you would store your globals in root:Packages:MyDataAcq. See Managing Package Data for details and examples.
On the other hand, if your package needs to create a group of variables and waves as a result of an operation on a single input wave, it makes sense to create your data folder in the one that holds the input wave (see the GetWavesDataFolder function). Similarly, if you create a package that takes an entire data folder as input (via a DFREF parameter pointing to the data folder) and needs to create a data folder containing output, it should create the output data folder in the one, or possibly at the same level as the one containing the input.
If your package creates and maintains windows, it should create a master data folder in root:Packages and then create individual data folders within the master that correspond to each instance of a window. For example, a Smith Chart package would create a master data folder as root:Packages:SmithCharts: and then create individual data folders inside the master with names that correspond to the individual graphs.
A package designed to operate on traces within graphs would go one step further and create a data folder for each trace that it has worked on, inside the data folder for the graph. This technique is illustrated by the Smooth Control Panel procedure file. For a demonstration, choose File→Examples→Feature Demos→Smoothing Control Panel.
Storing Runs Of Data​
If you acquire data using a well-established experimental protocol, your data will have a well-defined structure. Each time you run your protocol, you produce a new data set with the same structure. Storing each data set in its own data folder avoids name conflicts between corresponding items of different data sets. It also simplifies the writing of procedures to analyze and compare data set.
To use a trivial example, your data might have a structure like this:
<Run of data>
String: conditions
Variable: temperature
Wave: appliedVoltage
Wave: luminosity
Having defined this structure, you could then write procedures to:
  1. Load your data into a data folder
  2. Create a graph showing the data from one run
  3. Create a graph comparing the data from many runs
Writing these procedures is greatly simplified by the fact that the names of the items in a run are fixed. For example, step 2 could be written as:
Function GraphOneRun() // Graphs data from the run in the current data folder.
SVAR conditions
NVAR temperature
WAVE appliedVoltage, luminosity
Display luminosity vs appliedVoltage
String text
sprintf text, "Temperature: %g.\rExperimental conditions: %s.", temperature, conditions
Textbox text
To create a graph, you would first set the current data folder to point to a run of data and then you would invoke the GraphOneRun function.
The Data Folder Tutorial experiment shows in detail how to accomplish the three steps listed above. Choose File→Example Experiments→Tutorials→Data Folder Tutorial.
Setting and Restoring the Current Data Folder​
There are many reasons why you might want to save and restore the current data folder. In this example, we have a function that does a curve fit to a wave passed in as a parameter. The CurveFit operation creates two waves, W_coef and W_sigma, in the current data folder. If you use the /D option, it also creates a destination wave in the current data folder. In this function, we make sure that the W_coef, W_sigma and destination waves are all created in the same data folder as the source wave.
Function DoLineFit(w)
WAVE w
DFREF saveDF = GetDataFolderDFR()
SetDataFolder GetWavesDataFolder(w,1)
CurveFit line w /D
SetDataFolder saveDF
Many other operations create output waves in the current data folder. Depending on what your goal is, you may want to use the technique shown here to control where the output waves are created.
A function should always save and restore the current data folder unless it is designed explicitly to change the current data folder.
Determining a Function's Target Data Folder​
There are three common methods for determining the data folder that a function works on or in:
  1. Passing a wave in the target data folder as a parameter
  2. Having the function work on the current data folder
  3. Passing a DFREF parameter that points to the target data folder
For functions that operate on a specific wave, method 1 is appropriate.
For functions that operation on a large number of variables within a single data folder, methods 2 or 3 are appropriate. In method 2, the calling routine sets the data folder of interest as the current data folder. In method 3, the called function does this, and restores the original current data folder before it returns.
Clearing a Data Folder​
There are times when you might want to clear a data folder before running a procedure, to remove things left over from a preceding run. If the data folder contains no child data folders, you can achieve this with:
KillWaves/A/Z; KillVariables/A/Z
If the data folder does contain child data folders, you could use the KillDataFolder operation. This operation kills a data folder and its contents, including any child data folders. You could kill the main data folder and then recreate it. A problem with this is that, if the data folder or its children contain a wave that is in use, you will generate an error which will cause your function to abort.
Here is a handy function that kills the contents of a data folder and the contents of its children without killing any data folders and without attempting to kill any waves that may be in use.
Function ZapDataInFolderTree(path)
String path
SetDataFolder path
KillWaves/A/Z
KillVariables/A/Z
KillStrings/A/Z
Variable i
Variable numDataFolders = CountObjects(":",4)
for(i=0; i<numDataFolders; i+=1)
String nextPath = GetIndexedObjName(":",4,i)
ZapDataInFolderTree(nextPath)
Using Strings​
This section explains some common ways in which Igor procedures use strings. The most common techniques use built-in functions such as StringFromList and FindListItem. In addition to the built-in functions, there are a number of handy Igor procedure files in the WaveMetrics Procedures:Utilities:String Utilities folder.
Using Strings as Lists​
Procedures often need to deal with lists of items. Such lists are usually represented as semicolon-separated text strings. The StringFromList function is used to extract each item, often in a loop. For example:
Function Test()
Make jack,sam,fred,sue
String list = WaveList("*",";","")
Print list
Variable numItems = ItemsInList(list), i
for(i=0; i<numItems; i+=1)
Print StringFromList(i, list) // Print ith item
For lists with a large number of items, using StringFromList as shown above is slow. This is because it must search from the start of the list to the desired substring each time it is called. In Igor 7 or later, you can iterate quickly using the optional StringFromList offset parameter:
Function Test()
Print list
Variable offset = 0
String item = StringFromList(0, list, ";", offset) // Get ith item
Print item
offset += strlen(item) + 1
See ListToTextWave for another fast way to iterate through the items in a large string list.
Using Keyword-Value Packed Strings​
A collection of disparate values is often stored in a list of keyword-value pairs. For example, the TraceInfo and AxisInfo functions return such a list. The information in these strings follows this form
KEYWORD:value;KEYWORD:value; ...
The keyword is always upper case and followed by a colon. Then comes the value and a semicolon. When parsing such a string, you should avoid reliance on the specific ordering of keywords -- the order is likely to change in future releases of Igor.
Two functions will extract information from keyword-value strings. NumberByKey is used when the data is numeric, and StringByKey is used when the information is in the form of text.
Using Strings with Extractable Commands​
The AxisInfo and TraceInfo readback functions provide much of their information in a form that resembles the commands that you use to make the settings in the first place. For example, to set an axis to log mode, you would execute something like this:
ModifyGraph log(left)=1
If we now look at the characters of the string returned by AxisInfo we see:
AXTYPE:left;CWAVE:jack; ... RECREATION:grid(x)=0;log(x)=1 ...
To use this information, we need to extract the value following "log(x)=" and then use it in a ModifyGraph command with the extracted value with the desired graph as the target. Here is a user function that sets the log mode of the bottom axis to the same value as the left axis:
Function CopyLogMode()
String info,text
Variable pos
info=AxisInfo("","left")
pos= StrSearch(info,"RECREATION:",0) // skip to start of "RECREATION:"
pos += strlen("RECREATION:") // skip "RECREATION:", too
// get text after "log(x)="
text= StringByKey("log(x)",info[pos,inf],"=",";")
String cmd = "ModifyGraph log(bottom)=" + text
Execute cmd
Character-by-Character Operations​
Igor functions like strlen and strsearch, as well as Igor string indexing (see String Indexing), are byte-oriented. That is, strlen returns the number of bytes in a string. Strsearch takes a byte position as a parameter. Expressions like str[<index>] return a single byte.
In Igor 6, for western languages, each character is represented by a single byte, so the distinction between bytes and characters is insignificant, and byte-by-byte operations are sufficient.
In Igor 7 and later, which use the UTF-8 text encoding to represent text in strings, all ASCII characters are represented by one byte but all non-ASCII characters are represented by multiple bytes (see Text Encodings for details). Consequently, byte-by-byte operations are insufficient for stepping through characters. Character-by-character operations are needed.
There is no straightforward way to step through text containing non-ASCII characters. In the rare cases where this is necessary, you can use the user-defined functions shown in this section.
The following functions show how to step through UTF-8 text character-by-character rather than byte-by-byte.
// NumBytesInUTF8Character(str, byteOffset)
// Returns the number of bytes in the UTF-8 character that starts byteOffset
// bytes from the start of str.
// NOTE: If byteOffset is invalid this routine returns 0.
// Also, if str is not valid UTF-8 text, this routine return 1.
Function NumBytesInUTF8Character(str, byteOffset)
String str
Variable byteOffset
Variable numBytesInString = strlen(str)
if (byteOffset<0 || byteOffset>=numBytesInString)
return 0 // Programmer error
Variable firstByte = char2num(str[byteOffset]) & 0x00FF
if (firstByte < 0x80)
return 1
if (firstByte>=0xC2 && firstByte<=0xDF)
return 2
if (firstByte>=0xE0 && firstByte<=0xEF)
return 3
if (firstByte>=0xF0 && firstByte<=0xF4)
return 4
// If we are here, str is not valid UTF-8. Treat the first byte as a 1-byte character.
// This prevents infinite loops.
return 1
Function UTF8CharactersInString(str)
String str
Variable numCharacters = 0
Variable length = strlen(str)
Variable byteOffset = 0
do
if (byteOffset >= length)
break
Variable numBytesInCharacter = NumBytesInUTF8Character(str, byteOffset)
if (numBytesInCharacter <= 0)
Abort "Bug in CharactersInUTF8String" // Should not happen
numCharacters += 1
byteOffset += numBytesInCharacter
while(1)
return numCharacters
Function/S UTF8CharacterAtPosition(str, charPos)
String str
Variable charPos
if (charPos < 0)
// Print "charPos is invalid" // For debugging only
return ""
do
// Print "charPos is out-of-range" // For debugging only
return ""
if (charPos == 0)
break
charPos -= 1
while(1)
String result = str[byteOffset, byteOffset+numBytesInCharacter-1]
return result
Function DemoCharacterByCharacter()
String str = "AΔ♣∑B"
Variable numCharacters = UTF8CharactersInString(str)
Variable charPos
for(charPos=0; charPos<numCharacters; charPos+=1)
String character = UTF8CharacterAtPosition(str, charPos);
Printf "CharPos=%d, char=\"%s\"\r", charPos, character
See Also: Text Encodings, String Indexing
Working With Binary String Data​
Although Igor strings were originally conceived to store human-readable text such (e.g., "Hello, World"), advanced users have found them useful as containers for binary data. Such binary data is usually read from binary files, obtained from the Internet (e.g., via FetchURL or URLRequest), or obtained via data acquisition.
It is sometimes useful to store the bytes contained in a string into a byte wave so commands that work on waves can be used to analyze the contents. One example is determining the frequency of each letter in a piece of text for a linguistic analysis or analysis of DNA/RNA/protein sequences. Another use is to convert the bytes of a downloaded string into a numeric wave. Igor provides the StringToUnsignedByteWave and WaveDataToString functions to make facilitate such analyses. These functions were added in Igor Pro 9.00.
Examples can be found at https://www.wavemetrics.com/code-snippet/working-binary-string-data-examples.
Regular Expressions​
A regular expression is a pattern that is matched against a subject string from left to right. Regular expressions are used to identify lines of text containing a particular pattern and to extracts substrings matching a particular pattern.
A regular expression can contain regular characters that match the same character in the subject and special characters, called "metacharacters", that match any character, a list of specific characters, or otherwise identify patterns.
The regular expression syntax supported in Igor is based on PCRE - the Perl-Compatible Regular Expression Library.
This syntax is similar to regular expressions supported by various UNIX and POSIX egrep(1) commands.
See Regular Expressions References for details on PCRE.
Regular Expression Operations and Functions​
Here are the Igor operations and functions that work with regular expressions:
Grep
The Grep operation identifies lines of text that match a pattern.
The subject is each line of a file or each row of a text wave or each line of the text in the clipboard.
Output is stored in a file or in a text wave or in the clipboard.
Grep Example
Function DemoGrep()
Make/T source={"Monday","Tuesday","Wednesday","Thursday","Friday"}
Make/T/N=0 dest
Grep/E="sday" source as dest // Find rows containing "sday"
Print dest
The output from Print is:
dest[0]= {"Tuesday","Wednesday","Thursday"}
GrepList
The GrepList function identifies items that match a pattern in a string containing a delimited list.
The subject is each item in the input list.
The output is a delimited list returned as the function result.
GrepList Example
Function DemoGrepList()
String source = "Monday;Tuesday;Wednesday;Thursday;Friday"
String dest = GrepList(source, "sday") // Find items containing "sday"
Print dest
GrepString
The GrepString function determines if a particular pattern exists in the input string.
The subject is the input string.
The output is 1 if the input string contains the pattern or 0 if not.
GrepString Example
Function DemoGrepString()
String subject = "123.45"
String regExp = "[0-9]+" // Match one or more digits
Print GrepString(subject,regExp) // True if subject contains digit(s)
The output from Print is: 1
SplitString
The SplitString operation identifies subpatterns in the input string.
Output is stored in one or more string output variables.
SplitString Example
Function DemoSplitString()
String subject = "Thursday, May 7, 2009"
String regExp = "([[:alpha:]]+), ([[:alpha:]]+) ([[:digit:]]+), ([[:digit:]]+)"
String dayOfWeek, month, dayOfMonth, year
SplitString /E=(regExp) subject, dayOfWeek, month, dayOfMonth, year
Print dayOfWeek, month, dayOfMonth, year
Thursday May 7 2009
Basic Regular Expressions​
Here is a Grep command that uses "Fred" as the regular expression. "Fred" contains no metacharacters so this command identifies lines of text containing the literal string "Fred". It examines each line from the input file, afile.txt. All lines containing the pattern "Fred" are written to the output file, "FredFile.txt":
Grep/P=myPath/E="Fred" "afile.txt" as "FredFile.txt"
Character matching is case-sensitive by default. Prepending the Perl 5 modifier (?i) gives a case-insensitive pattern that matches upper and lower-case versions of "Fred":
// Copy lines that contain "Fred", "fred", "FRED", "fREd", etc
Grep/P=myPath/E="(?i)fred" "afile.txt" as "AnyFredFile.txt"
To copy lines that do not match the regular expression, use the Grep /E flag with the optional reverse parameter set to 1 to reverse the sense of the match:
// Copy lines that do NOT contain "Fred", "fred", "fREd", etc
Grep/P=myPath/E={"(?i)fred",1} "afile.txt" as "NotFredFile.txt"
note
Igor doesn't use the Perl opening and closing regular expression delimiter character which is the forward slash. In Perl you would use "/Fred/" and "/(?i)fred/".
Regular Expression Metacharacters​
The power of regular expressions comes from the ability to include alternatives and repetitions in the pattern. These are encoded in the pattern by the use of "metacharacters", which do not stand for themselves but instead are interpreted in some special way.
There are two different sets of metacharacters: those that are recognized anywhere in the pattern except within brackets, and those that are recognized in brackets. Outside brackets, the metacharacters are as follows:
\General escape character with several uses
^Match start of string
$Match end of string
.Match any character except newline (by default)
(To match newline, see Matching Newlines)
[Start character class definition (for matching one of a set of characters)
|Start of alternative branch (for matching one or the other of two patterns)
(Start subpattern
)End subpattern
?0 or 1 quantifier (for matching 0 or 1 occurrence of a pattern)
Also extends the meaning of (
Also quantifier minimizer
*0 or more quantifier (for matching 0 or more occurrence of a pattern)
+1 or more quantifier (for matching 1 or more occurrence of a pattern)
Also possessive quantifier
{Start min/max quantifier (for matching a number or range of occurrences)
Character Classes in Regular Expressions​
A character class is a set of characters and is used to specify that one character of the set should be matched. Character classes are introduced by a left-bracket and terminated by a right-bracket. For example:
[abc] Matches a or b or c
[A-Z] Matches any character from A to Z
[A-Za-z] Matches any character from A to Z or a to z.
POSIX character classes specify the characters to be matched symbolically. For example:
[[:alpha:]] Matches any alphabetic character (A to Z or a to z).
[[:digit:]] Matches 0 to 9.
In a character class the only metacharacters are:
^Negate the class, but only if ^ is the first character
-Indicates character range
[POSIX character class (only if followed by POSIX syntax)
]Terminates the character class
Backslash in Regular Expressions​
The backslash character has several uses. First, if it is followed by a nonalphanumeric character, it takes away any special meaning that character may have. This use of backslash as an escape character applies both inside and outside character classes.
For example, the * character normally means "match zero or more of the preceding subpattern". If you want to match a * character, you write * in the pattern. This escaping action applies whether or not the following character would otherwise be interpreted as a metacharacter, so it is always safe to precede a nonalphanumeric with backslash to specify that it stands for itself. In particular, if you want to match a backslash, you write \\.
note
Because Igor also has special uses for backslash (see Escape Sequences in Strings), you must double the number of backslashes you would normally use for a Perl or grep pattern. Each pair of backslashes tells Igor's compiler to send one backslash to, say, the Grep command.
For example, to copy lines that contain a backslash followed by a "z" character, the Perl pattern would be "\\z", but the equivalent Igor Grep expression would be /E="\\\\z".
Igor's input string parser converts "\\" to "\" so, when you write /E="\\\\z", the regular expression engine sees /E="\\z".
This difference is important enough that the PCRE and Igor Patterns (using Grep /E syntax) are both shown below when they differ.
Only ASCII numbers and letters have any special meaning after a backslash. All other characters are treated as literals.
If you want to remove the special meaning from a sequence of characters, you can do so by putting them between \Q and \E. This is different from Perl in that $ and @ are handled as literals in \Q...\E sequences in PCRE, whereas in Perl, $ and @ cause variable interpolation. Note the following examples:
Igor PatternPCRE PatternPCRE MatchesPerl Matches
\\Qabc$xyz\\E\Qabc$xyz\Eabc$xyzabc followed by the contents of $xyz
\\Qabc\\$xyz\\E\Qabc$xyz\Eabc\$xyzabc\$xyz
\\Qabc\\E\\$\\Qxyz\\E\Qabc\E\$\Qxyz\Eabc$xyzabc$xyz
The \Q...\E sequence is recognized both inside and outside character classes.
Backslash and Nonprinting Characters​
A second use of backslash provides a way of encoding nonprinting characters in patterns in a visible manner. There is no restriction on where nonprinting characters can occur, apart from the binary zero that terminates a pattern, but when a pattern is being prepared by text editing, it is usually easier to use one of the following escape sequences than the binary character it represents:
Igor PatternPCRE PatternCharacter Matched
\\a\aAlarm, that is, the BEL character (hex 07)
\\cx\cx"Control-x", where x is any character
\\e\eEscape (hex 1B)
\\f\fFormfeed (hex 0C)
\\n\nNewline (hex 0A)
\\r\rCarriage return (hex 0D)
\\t\tTab (hex 09)
\\ddd\dddCharacter with octal code ddd, or backreference
\\xhh\xhhCharacter with hex code hh
Backslash and Nonprinting Characters Arcania​
The material in this section is arcane and rarely needed. We recommend that you skip it.
The precise effect of \cx is if x is a lower case letter, it is converted to upper case. Then bit 6 of the character (hex 40) is inverted. Thus \cz becomes hex 1A, but \c{ becomes hex 3B, while \c; becomes hex 7B.
After \x, from zero to two hexadecimal digits are read (letters can be in upper or lower case). If characters other than hexadecimal digits appear between \x{ and }, or if there is no terminating }, this form of escape is not recognized. Instead, the initial \x will be interpreted as a basic hexadecimal escape, with no following digits, giving a character whose value is zero.
After \0 up to two further octal digits are read. In both cases, if there are fewer than two digits, just those that are present are used. Thus the sequence \0\x\07 specifies two binary zeros followed by a BEL character (code value 7). Make sure you supply two digits after the initial zero if the pattern character that follows is itself an octal digit.
The handling of a backslash followed by a digit other than 0 is complicated. Outside a character class, PCRE reads it and any following digits as a decimal number. If the number is less than 10, or if there have been at least that many previous capturing left parentheses in the expression, the entire sequence is taken as a back reference. A description of how this works is given later, following the discussion of parenthesized subpatterns.
Inside a character class, or if the decimal number is greater than 9 and there have not been that many capturing subpatterns, PCRE rereads up to three octal digits following the backslash, and generates a single byte from the least significant 8 bits of the value. Any subsequent digits stand for themselves. For example:
Igor PatternPCRE PatternCharacter(s) Matched
\\040\040Another way of writing a space
\\40\40A space, provided there are fewer than 40 previous capturing subpatterns
\\7\7Always a back reference
\\11\11Might be a back reference, or another way of writing a tab
\\011\011Always a tab
\\0113\0113A tab followed by the character "3"
\\113\113Might be a back reference, otherwise the character with octal code 113
\\377\377Might be a back reference, otherwise the byte consisting entirely of 1 bits
\\81\81Either a back reference or a binary zero followed by the two characters "8" and "1"
Note that octal values of 100 or greater must not be introduced by a leading zero, because no more than three octal digits are ever read.
All the sequences that define a single byte value can be used both inside and outside character classes. In addition, inside a character class, the sequence \b is interpreted as the backspace character (hex 08), and the sequence \X is interpreted as the character "X". Outside a character class, these sequences have different meanings (see Backslash and Nonprinting Characters).
Backslash and Generic Character Types​
The third use of backslash is for specifying generic character types. The following are always recognized:
\\d\dAny decimal digit
\\D\DAny character that is not a decimal digit
\\s\sAny whitespace character
\\S\SAny character that is not a whitespace character
\\w\wAny "word" character
\\W\WAny "nonword" character
Each pair of escape sequences, such as \d and \D, partitions the complete set of characters into two disjoint sets. Any given character matches one, and only one, of each pair.
These character type sequences can appear both inside and outside character classes. They each match one character of the appropriate type. If the current matching point is at the end of the subject string, all of them fail, since there is no character to match.
The \s whitespace characters are HT (9), LF (10), VT (11), FF (12), CR (13), and space (32). In Igor Pro 6 \s did not match the VT character (code 11).
A "word" character is an underscore or any character that is a letter or digit.
Backslash and Simple Assertions​
The fourth use of backslash is for certain simple assertions. An assertion specifies a condition that has to be met at a particular point in a match without consuming any characters from the subject string. The use of subpatterns for more complicated assertions is described in Assertions. The backslashed assertions are:
\\b\bAt a word boundary.
\\B\BNot at a word boundary.
\\A\AAt start of subject.
\\Z\ZAt end of subject or before newline at end.
\\z\zAt end of subject.
\\G\GAt first matching position in subject.
These assertions may not appear in character classes (but note that \b has a different meaning, namely the backspace character, inside a character class).
A word boundary is a position in the subject string where the current character and the previous character do not both match \w or \W (i.e. one matches \w and the other matches \W), or the start or end of the string if the first or last character matches \w, respectively.
While PCRE defines additional simple assertions (\A, \Z, \z and \G), they are not any more useful to Igor's regular expression commands than the ^ and $ characters.
Circumflex and Dollar​
( ^ and $)
Outside a character class, in the default matching mode, the circumflex character ^ is an assertion that is true only if the current matching point is at the start of the subject string. Inside a character class, circumflex has an entirely different meaning (see Character Classes and Brackets).
Circumflex need not be the first character of the pattern if a number of alternatives are involved, but it should be the first thing in each alternative in which it appears if the pattern is ever to match that branch. If all possible alternatives start with a circumflex, that is, if the pattern is constrained to match only at the start of the subject, it is said to be an "anchored" pattern. (There are also other constructs that can cause a pattern to be anchored.)
A dollar character $ is an assertion that is true only if the current matching point is at the end of the subject string, or immediately before a newline character that is the last character in the string (by default). Dollar need not be the last character of the pattern if a number of alternatives are involved, but it should be the last item in any branch in which it appears. Dollar has no special meaning in a character class.
Dot, Period, or Full Stop​
Outside a character class, a dot in the pattern matches any one character in the subject, including a nonprinting character, but not (by default) newline. Dot has no special meaning in a character class.
The match option setting (?s) changes the default behavior of dot so that it matches any character including newline. The setting can appear anywhere before the dot in the pattern. See Matching Newlines for details.
Character Classes and Brackets​
An opening bracket introduces a character class which is terminated by a closing bracket. A closing bracket on its own is not special. If a closing bracket is required as a member of the class, it must be the first data character in the class (after an initial circumflex, if present) or escaped with a backslash.
A character class matches a single character in the subject. A matched character must be in the set of characters defined by the class, unless the first character in the class definition is a circumflex, in which case the subject character must not be in the set defined by the class. If a circumflex is actually required as a member of the class, ensure it is not the first character, or escape it with a backslash.
For example, the character class [aeiou] matches any English lower case vowel, while [^aeiou] matches any character that is not an English lower case vowel. Note that a circumflex is just a convenient notation for specifying the characters that are in the class by enumerating those that are not.
When caseless matching is set, using the (?i) match option setting, any letters in a class represent both their upper case and lower case versions, so for example, the caseless pattern (?i)[aeiou] matches "A" as well as "a", and the caseless pattern (?i)[^aeiou] does not match "A".
The minus (hyphen) character can be used to specify a range of characters in a character class. For example, [d-m] matches any letter between d and m, inclusive. If a minus character is required in a class, it must be escaped with a backslash or appear in a position where it cannot be interpreted as indicating a range, typically as the first or last character in the class.
To include a right-bracket in a range you must use \]. As usual, this would be represented in a literal Igor string as \\].
Though it is rarely needed, you can specify a range using octal numbers, for example [\000-\037].
The character types \d, \D, \p, \P, \s, \S, \w, and \W may also appear in a character class, and add the characters that they match to the class. For example, [\dABCDEF] matches any hexadecimal digit. A circumflex can conveniently be used with the upper case character types to specify a more restricted set of characters than the matching lower case type. For example, the class [^\W_] matches any letter or digit, but not underscore. The corresponding Grep command would begin with
Grep/E="[^\\W_]" ...
The only metacharacters that are recognized in character classes are backslash, hyphen (only where it can be interpreted as specifying a range), circumflex (only at the start), opening bracket (only when it can be interpreted as introducing a POSIX class name - see the next section), and the terminating closing bracket. However, escaping other nonalphanumeric characters does no harm.
POSIX Character Classes​
[:name:]
Perl supports the POSIX notation for character classes. This uses names enclosed by [: and :] within the enclosing brackets. PCRE also supports this notation. For example,
[01[:alpha:]%]
matches "0", "1", any alphabetic character, or "%".
The supported class names, all of which must appear between [: and :] inside a character class specification, are
alnumLetters and digits.
alphaLetters.
asciiCharacter codes 0 - 127.
blankSpace or tab only.
cntrlControl characters.
digitDecimal digits (same as \d).
graphPrinting characters, excluding space.
[:graph:] matches all characters with the Unicode L, M, N, P, S, or Cf properties with a few arcane exceptions.
lowerLower case letters.
printPrinting characters, including space.
[:print:] matches the same characters as [:graph:] plus space characters that are not controls, that is, characters with the Unicode Zs property.
punctPrinting characters, excluding letters and digits.
[:punct:] matches all characters that have the Unicode P (punctuation) property, plus those characters whose code points are less than 128 that have the S (Symbol) property.
spaceWhite space (not quite the same as \s).
upperUpper case letters.
word"Word" characters (same as \w).
xdigitHexadecimal digits.
The "space" characters are horizontal tab (HT-9), linefeed (LF-10), vertical tab (VT-11), formfeed (FF-12), carriage-return (CR-13), and space (32).
The class name "word" is a Perl extension, and "blank" is a GNU extension from Perl 5.8. Another Perl extension is negation as indicated by a ^ character after the colon. For example,
[12[:^digit:]]
matches "1", "2", or any nondigit. PCRE (and Perl) also recognize the POSIX syntax [.ch.] and [=ch=] where "ch" is a "collating element", but these are not supported, and an error is given if they are encountered.
Alternation​
Vertical bar characters are used to separate alternative patterns. For example, the pattern:
gilbert|sullivan
matches either "gilbert" or "sullivan". Any number of alternative patterns may be specified, and an empty alternative is permitted (matching the empty string). The matching process tries each alternative in turn, from left to right, and the first one that succeeds is used. If the alternatives are within a subpattern (defined below), "succeeds" means matching the rest of the main pattern as well as the alternative in the subpattern.
Match Option Settings​
(?chars)
Character matching options can be changed from within the pattern by a sequence of Perl option letters enclosed between "(?" and ")". The option letters are:
OptionPCRE NameCharacters Matched
iPCRE_CASELESSUpper and lower case.
mPCRE_MULTILINE^ matches start of string and just after a new line (\n). $ matches end of string and just before a new line. Without (?m), ^ and $ match only the start and end of the entire string.
sPCRE_DOTALL. matches all characters including newline. Without (?s), . does not match newlines. See Matching Newlines.
UPCRE_UNGREEDYReverses the "greediness" of the quantifiers so that they are not greedy by default, but become greedy if followed by ?.
For example, (?i) sets caseless matching.
You can unset these options by preceding the letter with a hyphen: (?-i) turns off caseless matching.
You can combine a setting and unsetting such as (?i-U), which sets PCRE_CASELESS while unsetting PCRE_UNGREEDY.
When an option change occurs at top level (that is, not inside subpattern parentheses), the change applies to the remainder of the pattern that follows. If the change is placed right at the start of a pattern, PCRE extracts it into the global options.
An option change within a subpattern affects only that part of the current pattern that follows it, so
(a(?i)b)c
matches abc and aBc and no other strings.
Any changes made in one alternative do carry on into subsequent branches within the same subpattern. For example,
(a(?i)b|c)
matches "ab", "aB", "c", and "C", even though when matching "C" the first branch is abandoned before the option setting. This is because the effects of option settings happen at compile time.
The other PCRE-specific options (m, s, x, and X) are not useful with Igor's regular expression commands.
Matching Newlines​
Igor generally uses carriage-return (ASCII code 13) return to indicate a new line in text. This is represented in a literal string by "\r". For example:
Print "Hello\rGoodbye"
prints two lines of text to the history area.
However, in regular expressions, the newline character is linefeed (ASCII code 10). This is represented in a literal string by "\n". Carriage-return has no special status in regular expressions.
The match option setting (?s) changes the default behavior of dot so that it matches any character including newline. The setting can appear anywhere before the dot in the pattern. For example:
Function DemoNewline(includeNewline)
Variable includeNewline
String subject = "Hello\nGoodbye" // \n represents newline
String regExp
if (includeNewline)
regExp = "(?s)(.+)" // Match one or more occurrence of any character
regExp = "(.+)" // Match one or more occurrence of any character except newline
String result
SplitString /E=(regExp) subject, result
Print result
The output from DemoNewline(0) is:
Hello
The output from DemoNewline(1) is:
Hello\nGoodbye
Here is a more realistic example:
Function DemoDotAll()
String theString = ExampleHTMLString()
// This regular expression attempts to extract items from HTML code
// for an ordered list. It fails because the HTML code contains newlines
// and, by default, . does not match newlines.
String regExpFails="<li>(.*?)</li>.*<li>(.*?)</li>"
String str1, str2
SplitString/E=regExpFails theString, str1, str2
Print V_flag, " subpatterns were matched using regExpFails"
Printf "\"%s\", \"%s\"\r", str1, str2
// This regular expression works because the "(?s)" match option setting
// causes . to match newlines.
String regExpWorks="(?s)<li>(.*?)</li>.*<li>(.*?)</li>"
SplitString/E=regExpWorks theString, str1, str2
Print V_flag, " subpatterns were matched using regExpWorks"
Function/S ExampleHTMLString() // Returns HTML code containing newlines
String theString = ""
theString += "<ol>\n"
theString += "\t<li>item 1</li>\n"
theString += "\t<li>item 2</li>\n"
theString += "<\ol>\n"
return theString
•DemoDotAll()
0 subpatterns were matched using regExpFails
2 subpatterns were matched using regExpWorks
"item 1", "item 2"
Subpatterns​
Subpatterns are used to group alternatives, to match a previously-matched pattern again, and to extract match text using SplitString.
Subpatterns are delimited by parentheses, which can be nested. Turning part of a pattern into a subpattern localizes a set of alternatives. For example, this pattern (which includes two vertical bars signifying alternation):
cat(aract|erpillar|)
matches one of the words "cat", "cataract", or "caterpillar". Without the parentheses, it would match "cataract", "erpillar" or the empty string.
Named Subpatterns​
?P<name>
Specifying subpatterns by number is simple, but it can be very hard to keep track of the numbers in complicated regular expressions. Furthermore, if an expression is modified, the numbers may change. To help with this difficulty, PCRE supports the naming of subpatterns, something that Perl does not provide. The Python syntax (?P<name>...) is used. For example:
My (?P<catdog>cat|dog) is cooler than your (?P=catdog)
Here catdog is the name of the first and only subpattern. ?P<catdog> names the subpattern and (?P=catdog) matches the previous match for that subpattern.
Names consist of alphanumeric characters and underscores, and must be unique within a pattern.
Named capturing parentheses are still allocated numbers as well as names. This has the same effect as the previous example:
My (?P<catdog>cat|dog) is cooler than your \\1
Repetition​
Repetition is specified by quantifiers:
?0 or 1 quantifier
Example: [abc]? - Matches 0 or 1 occurrences of a or b or c
Example: [abc]* - Matches 0 or more occurrences of a or b or c
Example: [abc]+ - Matches 1 or more occurrences of a or b or c
{n}n times quantifier
Example: [abc]{3} - Matches 3 occurrences of a or b or c
{n,m}n to m times quantifier
Example: [abc]{3,5} - Matches 3 to 5 occurrences of a or b or c
Quantifiers can follow any of the following items:
  • A literal data character
  • The . metacharacter
  • The \C escape sequence
  • An escape such as \d that matches a single character
  • A character class
  • A back reference (see Back References)
  • A parenthesized subpattern (unless it is an assertion)
The general repetition quantifier specifies a minimum and maximum number of permitted matches, by giving the two numbers in braces, separated by a comma. The numbers must be less than 65536, and the first must be less than or equal to the second. For example:
z{2,4}
matches "zz", "zzz", or "zzzz".
If the second number is omitted, but the comma is present, there is no upper limit; if the second number and the comma are both omitted, the quantifier specifies an exact number of required matches. Thus
[aeiou]{3,}
matches at least 3 successive vowels, but may match many more, while
\d{8}
matches exactly 8 digits. A left brace that appears in a position where a quantifier is not allowed, or one that does not match the syntax of a quantifier, is taken as a literal character. For example, {,6} is not a quantifier, but a literal string of four characters.
Quantifiers apply to characters rather than to individual data units. Thus, for example, \x{100}{2} matches two characters, each of which is represented by a two-byte sequence in a UTF-8 string. Similarly, \X{3} matches three Unicode extended grapheme clusters, each of which may be several data units long (and they may be of different lengths).
The quantifier {0} is permitted, causing the expression to behave as if the previous item and the quantifier were not present.
For convenience (and historical compatibility) the three most common quantifiers have single-character abbreviations:
*Equivalent to {0,}
+Equivalent to {1,}
?Equivalent to {0,1}
It is possible to construct infinite loops by following a subpattern that can match no characters with a quantifier that has no upper limit, for example:
(a?)*
Earlier versions of Perl and PCRE used to give an error at compile time for such patterns. However, because there are cases where this can be useful, such patterns are now accepted, but if any repetition of the subpattern does in fact match no characters, the loop is forcibly broken.
Quantifier Greediness​
By default, the quantifiers are "greedy", that is, they match as much as possible (up to the maximum number of permitted times), without causing the rest of the pattern to fail. The classic example of where this gives problems is in trying to match comments in C programs. These appear between /* and */ and within the comment, individual * and / characters may appear. An attempt to match C comments by applying the pattern
/\*.*\*/ or Grep/E="/\\*.*\\*/"
to the string
/* first comment */ not comment /* second comment */
fails because it matches the entire string owing to the greediness of the .* item.
However, if a quantifier is followed by a question mark, it ceases to be greedy, and instead matches the minimum number of times possible, so the pattern
/\*.*?\*/ or Grep/E="/\\*.*?\\*/"
does the right thing with the C comments. The meaning of the various quantifiers is not otherwise changed, just the preferred number of matches.
Do not confuse this use of question mark with its use as a quantifier in its own right. Because it has two uses, it can sometimes appear doubled, as in
\d??\d or Grep/E="\\d??\\d"
which matches one digit by preference, but can match two if that is the only way the rest of the pattern matches.
If the PCRE_UNGREEDY option (?U) is set, the quantifiers are not greedy by default, but individual ones can be made greedy by following them with a question mark. In other words, it inverts the default behavior.
Quantifiers With Subpatterns​
When a parenthesized subpattern is quantified with a minimum repeat count that is greater than 1 or with a limited maximum, more memory is required for the compiled pattern, in proportion to the size of the minimum or maximum.
When a capturing subpattern is repeated, the value captured is the substring that matched the final iteration. For example, after
(tweedle[dume]{3}\s*)+ or Grep/E="(tweedle[dume]{3}\\s*)+"
has matched "tweedledum tweedledee" the value of the captured substring is "tweedledee". However, if there are nested capturing subpatterns, the corresponding captured values may have been set in previous iterations. For example, after
/(a|(b))+/
matches "aba" the value of the second captured substring is "b".
Atomic Grouping and Possessive Quantifiers​
With both maximizing and minimizing repetition, failure of what follows normally reevaluates the repeated item to see if a different number of repeats allows the rest of the pattern to match. Sometimes it is useful to prevent this, either to change the nature of the match, or to cause it fail earlier than it otherwise might, when the author of the pattern knows there is no point in carrying on.
Consider, for example, the pattern \d+foo when applied to the subject line
123456bar
After matching all 6 digits and then failing to match "foo", the normal action of the matcher is to try again with only 5 digits matching the \d+ item, and then with 4, and so on, before ultimately failing. "Atomic grouping" provides the means for specifying that once a subpattern has matched, it is not to be reevaluated in this way.
If we use atomic grouping for the previous example, the matcher would give up immediately on failing to match "foo" the first time. The notation is a kind of special parenthesis, starting with (?> as in this example:
(?>\d+)foo or Grep/E="(?>\\d+)foo"
This kind of parenthesis "locks up" the part of the pattern it contains once it has matched, and a failure further into the pattern is prevented from backtracking into it. Backtracking past it to previous items, however, works as normal.
An alternative description is that a subpattern of this type matches the string of characters that an identical standalone pattern would match, if anchored at the current point in the subject string.
Atomic grouping subpatterns are not capturing subpatterns. Simple cases such as the above example can be thought of as a maximizing repeat that must swallow everything it can. So, while both \d+ and \d+? are prepared to adjust the number of digits they match in order to make the rest of the pattern match, (?>\d+) can only match an entire sequence of digits.
Atomic groups in general can of course contain arbitrarily complicated subpatterns, and can be nested. However, when the subpattern for an atomic group is just a single repeated item, as in the example above, a simpler notation, called a "possessive quantifier" can be used. This consists of an additional + character following a quantifier. Using this notation, the previous example can be rewritten as
\d++foo or Grep/E="\\d++foo"
Possessive quantifiers are always greedy; the setting of the PCRE_UNGREEDY option is ignored. They are a convenient notation for the simpler forms of atomic group. However, there is no difference in the meaning or processing of a possessive quantifier and the equivalent atomic group.
The possessive quantifier syntax is an extension to the Perl syntax. It originates in Sun's Java package.
When a pattern contains an unlimited repeat inside a subpattern that can itself be repeated an unlimited number of times, the use of an atomic group is the only way to avoid some failing matches taking a very long time indeed. The pattern
(\D+|<\d+>)*[!?] or Grep/E="(\\D+|<\\d+>)*[!?]"
matches an unlimited number of substrings that either consist of nondigits, or digits enclosed in <>, followed by either ! or ?. When it matches, it runs quickly. However, if it is applied to
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
it takes a long time before reporting failure. This is because the string can be divided between the internal \D+ repeat and the external * repeat in a large number of ways, and all have to be tried. (The example uses [!?] rather than a single character at the end, because both PCRE and Perl have an optimization that allows for fast failure when a single character is used. They remember the last single character that is required for a match, and fail early if it is not present in the string.) If the pattern is changed so that it uses an atomic group, like this:
((?>\D+)|<\d+>)*[!?] or Grep/E="((?>\\D+)|<\\d+>)*[!?]"
sequences of nondigits cannot be broken, and failure happens quickly.
Back References​
Outside a character class, a backslash followed by a digit greater than 0 (and possibly further digits) is a back reference to a capturing subpattern earlier (that is, to its left) in the pattern, provided there have been that many previous capturing left parentheses.
However, if the decimal number following the backslash is less than 10, it is always taken as a back reference, and causes an error only if there are not that many capturing left parentheses in the entire pattern. In other words, the parentheses that are referenced need not be to the left of the reference for numbers less than 10. See Backslash and Nonprinting Characters for further details of the handling of digits following a backslash.
A back reference matches whatever actually matched the capturing subpattern in the current subject string, rather than anything matching the subpattern itself (see Subpatterns as Subroutines for a way of doing that). So the pattern
(sens|respons)e and \1ibility or /E="(sens|respons)e and \\1ibility"
matches "sense and sensibility" and "response and responsibility", but not "sense and responsibility". If caseful matching is in force at the time of the back reference, the case of letters is relevant. For example,
((?i)rah)\s+\1 or Grep/E="((?i)rah)\\s+\\1"
matches "rah rah" and "RAH RAH", but not "RAH rah", even though the original capturing subpattern is matched caselessly.
Back references to named subpatterns use the Python syntax (?P<*name>*). We could rewrite the above example as follows:
(?P<p1>(?i)rah)\s+(?P=p1) or Grep/E="(?P<p1>(?i)rah)\\s+(?P=p1)"
There may be more than one back reference to the same subpattern. If a subpattern has not actually been used in a particular match, any back references to it always fail. For example, the pattern
(a|(bc))\2
always fails if it starts to match "a" rather than "bc". Because there may be many capturing parentheses in a pattern, all digits following the backslash are taken as part of a potential back reference number. If the pattern continues with a digit character, some delimiter must be used to terminate the back reference. An empty comment (see Regular Expression Comments) can be used.
A back reference that occurs inside the parentheses to which it refers fails when the subpattern is first used, so, for example, (a\1) never matches. However, such references can be useful inside repeated subpatterns. For example, the pattern:
(a|b\1)+ or Grep/E="(a|b\\1)+"
matches any number of a 's and also "aba", "ababbaa" etc. At each iteration of the subpattern, the back reference matches the character string corresponding to the previous iteration. In order for this to work, the pattern must be such that the first iteration does not need to match the back reference. This can be done using alternation, as in the example above, or by a quantifier with a minimum of zero.
Assertions​
An assertion is a test on the characters following or preceding the current matching point that does not actually consume any characters. The simple assertions coded as \b, \B, ^ and $ are described in Backslash and Simple Assertions.
More complicated assertions are coded as subpatterns. There are two kinds: those that look ahead of the current position in the subject string, and those that look behind it. An assertion subpattern is matched in the normal way, except that it does not cause the current matching position to be changed.
Assertion subpatterns are not capturing subpatterns, and may not be repeated, because it makes no sense to assert the same thing several times. If any kind of assertion contains capturing subpatterns within it, these are counted for the purposes of numbering the capturing subpatterns in the whole pattern. However, substring capturing is carried out only for positive assertions, because it does not make sense for negative assertions.
Lookahead Assertions​
Lookahead assertions start with (?= for positive assertions and (?! for negative assertions. For example,
\w+(?=;) or Grep/E="\\w+(?=;)"
matches a word followed by a semicolon, but does not include the semicolon in the match, and
foo(?!bar)
matches any occurrence of "foo" that is not followed by "bar". Note that the apparently similar pattern
(?!foo)bar
does not find an occurrence of "bar" that is preceded by something other than "foo"; it finds any occurrence of "bar" whatsoever, because the assertion (?!foo) is always true when the next three characters are "bar". A lookbehind assertion is needed to achieve the other effect.
If you want to force a matching failure at some point in a pattern, the most convenient way to do it is with (?!) because an empty string always matches, so an assertion that requires there not to be an empty string must always fail.
Lookbehind Assertions​
Lookbehind assertions start with (?<= for positive assertions and (?<! for negative assertions. For example,
(?<!foo)bar
does find an occurrence of "bar" that is not preceded by "foo". The contents of a lookbehind assertion are restricted such that all the strings it matches must have a fixed length. However, if there are several alternatives, they do not all have to have the same fixed length. Thus
(?<=bullock|donkey)
is permitted, but
(?<!dogs?|cats?)
causes an error at compile time. Branches that match different length strings are permitted only at the top level of a lookbehind assertion. This is an extension compared with Perl (at least for 5.8), which requires all branches to match the same length of string. An assertion such as
(?<=ab(c|de))
is not permitted, because its single top-level branch can match two different lengths, but it is acceptable if rewritten to use two top-level branches:
(?<=abc|abde)
In some cases, the escape sequence \K (see above) can be used instead of a lookbehind assertion to get round the fixed-length restriction.
The implementation of lookbehind assertions is, for each alternative, to temporarily move the current position back by the fixed width and then try to match. If there are insufficient characters before the current position, the match is deemed to fail.
PCRE does not allow the \C escape (which matches a single data unit) to appear in lookbehind assertions, because it makes it impossible to calculate the length of the lookbehind. The \X and \R escapes, which can match different numbers of data units, are also not permitted.
Atomic groups can be used in conjunction with lookbehind assertions to specify efficient matching at the end of the subject string. Consider a simple pattern such as
abcd$
when applied to a long string that does not match. Because matching proceeds from left to right, PCRE will look for each "a" in the subject and then see if what follows matches the rest of the pattern. If the pattern is specified as
^.*abcd$
the initial .* matches the entire string at first, but when this fails (because there is no following "a"), it backtracks to match all but the last character, then all but the last two characters, and so on. Once again the search for "a" covers the entire string, from right to left, so we are no better off. However, if the pattern is written as
^(?>.*)(?<=abcd)
or, equivalently, using the possessive quantifier syntax,
^.*+(?<=abcd)
there can be no backtracking for the .* item; it can match only the entire string. The subsequent lookbehind assertion does a single test on the last four characters. If it fails, the match fails immediately. For long strings, this approach makes a significant difference to the processing time.
Using Multiple Assertions​
Several assertions (of any sort) may occur in succession. For example,
(?<=\d{3})(?<!999)foo or Grep/E="(?<=\\d{3})(?<!999)foo"
matches "foo" preceded by three digits that are not "999". Notice that each of the assertions is applied independently at the same point in the subject string. First there is a check that the previous three characters are all digits, and then there is a check that the same three characters are not "999". This pattern does not match "foo" preceded by six characters, the first of which are digits and the last three of which are not "999". For example, it doesn't match "123abcfoo". A pattern to do that is
(?<=\d{3}...)(?<!999)foo or Grep/E="(?<=\\d{3}...)(?<!999)foo"
This time the first assertion looks at the preceding six characters, checking that the first three are digits, and then the second assertion checks that the preceding three characters are not "999".
Assertions can be nested in any combination. For example,
(?<=(?<!foo)bar)baz
matches an occurrence of "baz" that is preceded by "bar" which in turn is not preceded by "foo", while
(?<=\d{3}(?!999)...)foo or Grep/E=" (?<=\\d{3}(?!999)...)foo"
is another pattern that matches "foo" preceded by three digits and any three characters that are not "999".
Conditional Subpatterns​
It is possible to cause the matching process to obey a subpattern conditionally or to choose between two alternative subpatterns, depending on the result of an assertion, or whether a previous capturing subpattern matched or not. The two possible forms of conditional subpattern are
(?(condition)yes-pattern)
(?(condition)yes-pattern|no-pattern)
If the condition is satisfied, the yes-pattern is used; otherwise the no-pattern (if present) is used. If there are more than two alternatives in the subpattern, a compile-time error occurs.
There are three kinds of condition. If the text between the parentheses consists of a sequence of digits, the condition is satisfied if the capturing subpattern of that number has previously matched. The number must be greater than zero. Consider the following pattern, which contains nonsignificant white space to make it more readable and to divide it into three parts for ease of discussion:
( \( )? [^()]+ (?(1) \) )
The first part matches an optional opening parenthesis, and if that character is present, sets it as the first captured substring. The second part matches one or more characters that are not parentheses. The third part is a conditional subpattern that tests whether the first set of parentheses matched or not. If they did, that is, if subject started with an opening parenthesis, the condition is true, and so the yes-pattern is executed and a closing parenthesis is required. Otherwise, since no-pattern is not present, the subpattern matches nothing. In other words, this pattern matches a sequence of nonparentheses, optionally enclosed in parentheses.
If the condition is the string (R), it is satisfied if a recursive call to the pattern or subpattern has been made. At "top level", the condition is false. This is a PCRE extension. Recursive patterns are described in the next section.
If the condition is not a sequence of digits or (R), it must be an assertion. This may be a positive or negative lookahead or lookbehind assertion. Consider this pattern, again containing nonsignificant white space, and with the two alternatives on the second line:
(?(?=[^a-z]*[a-z])
\d{2}-[a-z]{3}-\d{2} | \d{2}-\d{2}-\d{2} )
The condition is a positive lookahead assertion that matches an optional sequence of nonletters followed by a letter. In other words, it tests for the presence of at least one letter in the subject. If a letter is found, the subject is matched against the first alternative; otherwise it is matched against the second. This pattern matches strings in one of the two forms dd-aaa-dd or dd-dd-dd, where aaa are letters and dd are digits.
Regular Expression Comments​
The sequence (?# marks the start of a comment that continues up to the next closing parenthesis. Nested parentheses are not permitted. The characters that make up a comment play no part in the pattern matching at all.
Recursive Patterns​
Consider the problem of matching a string in parentheses, allowing for unlimited nested parentheses. Without the use of recursion, the best that can be done is to use a pattern that matches up to some fixed depth of nesting. It is not possible to handle an arbitrary nesting depth. Perl provides a facility that allows regular expressions to recurse (amongst other things). It does this by interpolating Perl code in the expression at runtime, and the code can refer to the expression itself. A Perl pattern to solve the parentheses problem can be created like this:
$re = qr{\( (?: (?>[^()]+) | (?p{$re}) )* \)}x;
the (?p{...}) item interpolates Perl code at runtime, and in this case refers recursively to the pattern in which it appears. Obviously, PCRE cannot support the interpolation of Perl code. Instead, it supports some special syntax for recursion of the entire pattern, and also for individual subpattern recursion.
The special item that consists of (? followed by a number greater than zero and a closing parenthesis is a recursive call of the subpattern of the given number, provided that it occurs inside that subpattern. (If not, it is a "subroutine" call, which is described in Subpatterns as Subroutines.) The special item (?R) is a recursive call of the entire regular expression.
For example, this PCRE pattern solves the nested parentheses problem (additional nonfunction whitespace has been added to separate the expression into parts):
\( ( (?>[^()]+) | (?R) )* \)
First it matches an opening parenthesis. Then it matches any number of substrings which can either be a sequence of nonparentheses, or a recursive match of the pattern itself (that is a correctly parenthesized substring). Finally there is a closing parenthesis.
If this were part of a larger pattern, you would not want to recurse the entire pattern, so instead you could use this:
( \( ( (?>[^()]+) | (?1) )* \) )
We have put the pattern into parentheses, and caused the recursion to refer to them instead of the whole pattern. In a larger pattern, keeping track of parenthesis numbers can be tricky. It may be more convenient to use named parentheses instead. For this, PCRE uses (?P>name), which is an extension to the Python syntax that PCRE uses for named parentheses (Perl does not provide named parentheses). We could rewrite the above example as follows:
(?P<pn> \( ( (?>[^()]+) | (?P>pn) )* \) )
This particular example pattern contains nested unlimited repeats, and so the use of atomic grouping for matching strings of nonparentheses is important when applying the pattern to strings that do not match. For example, when this pattern is applied to
(aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa()
it yields "no match" quickly. However, if atomic grouping is not used, the match runs for a very long time indeed because there are so many different ways the + and * repeats can carve up the subject, and all have to be tested before failure can be reported.
At the end of a match, the values set for any capturing subpatterns are those from the outermost level of the recursion at which the subpattern value is set. If you want to obtain intermediate values, a callout function can be used (see Subpatterns as Subroutines). If the pattern above is matched against
(ab(cd)ef)
the value for the capturing parentheses is "ef", which is the last value taken on at the top level. If additional parentheses are added, giving
\( ( ( (?>[^()]+) | (?R) )* ) \)
the string they capture is "ab(cd)ef", the contents of the top level parentheses. If there are more than 15 capturing parentheses in a pattern, PCRE has to obtain extra memory to store data during a recursion, which it does by using pcre_malloc, freeing it via pcre_free afterward. If no memory can be obtained, the match fails with the PCRE_ERROR_NOMEMORY error.
Do not confuse the (?R) item with the condition (R), which tests for recursion. Consider this pattern, which matches text in angle brackets, allowing for arbitrary nesting. Only digits are allowed in nested brackets (that is, when recursing), whereas any characters are permitted at the outer level.
< (?: (?(R) \d++ | [^<>]*+) | (?R)) * >
In this pattern, (?(R) is the start of a conditional subpattern, with two different alternatives for the recursive and nonrecursive cases. The (?R) item is the actual recursive call.
Subpatterns as Subroutines​
If the syntax for a recursive subpattern reference (either by number or by name) is used outside the parentheses to which it refers, it operates like a subroutine in a programming language. An earlier example pointed out that the pattern
matches "sense and sensibility" and "response and responsibility", but not "sense and responsibility". If instead the pattern
(sens|respons)e and (?1)ibility
is used, it does match "sense and responsibility" as well as the other two strings. Such references must, however, follow the subpattern to which they refer.
Regular Expressions References​
The regular expression syntax supported by Grep, GrepString, GrepList and SplitString is based on the PCRE -- Perl-Compatible Regular Expression Library by Philip Hazel, University of Cambridge, Cambridge, England. The PCRE library is a set of functions that implement regular expression pattern matching using the same syntax and semantics as Perl 5.
Visit http://pcre.org/ for more information about the PCRE library. The description of Regular Expressions above is taken from the PCRE documentation.
A good introductory book on regular expressions is: Forta, Ben, Regular Expressions in 10 Minutes, Sams Publishing, 2004.
A good comprehensive book on regular expressions is: Friedl, Jeffrey E. F., Mastering Regular Expressions, 2nd ed., 492 pp., O'Reilly Media, 2002.
A good web site is: http://www.regular-expressions.info/
Working with Files​
Here are the built-in operations that you can use to read from or write to files:
OperationWhat It Does
OpenOpens an existing file for reading or writing. Can also create a new file. Can also append to an existing file. Returns a file reference number that you must pass to the other file operations.
Use Open/D to present a dialog that allows the user to choose a file without actually opening the file.
fprintfWrites formatted text to an open file.
wfprintfWrites wave data as formatted text to an open file.
FGetPosGets the position at which the next file read or write will be done.
FSetPosSets the position at which the next file read or write will be done.
FStatusGiven a file reference number, returns miscellaneous information about the file.
FBinReadReads binary data from a file into an Igor string, variable or wave. This is used mostly to read nonstandard file formats.
FBinWriteWrites binary data from an Igor string, variable or wave. This is used mostly to write nonstandard file formats.
FReadLineReads a line of text from a text file into an Igor string variable. This can be used to parse an arbitrary format text file.
CloseCloses a file opened by the Open operation.
Before working with a file, you must use the Open operation to obtain a file reference number that you use with all the remaining commands. The Open operation creates new files, appends data to an existing file, or reads data from an existing file.
Sometimes you may write a procedure that uses the Open operation and the Close operation but, because of an error, the Close operation never gets to execute. You then correct the procedure and want to rerun it. The file will still be open because the Close operation never got a chance to run. In this case, execute:
Close/A
from the command line to close all open files.
Finding Files​
Two functions are provided to help you to determine what files exist in a particular folder:
  • TextFile
  • IndexedFile
IndexedFile is a more general version of TextFile.
You can also use the Open operation with the /D flag to present an open dialog.
Igor Pro also supports a number of other operations and functions for file or folder manipulation:
CopyFileCopyFolder
DeleteFileDeleteFolder
GetFileFolderInfoSetFileFolderInfo
MoveFileMoveFolder
CreateAliasShortcut
NewPathPathInfo
ParseFilePath
warning
Use caution when writing code that deletes or moves files or folders. These actions are not undoable.
Because the DeleteFolder, CopyFolder and MoveFolder operations have the potential to do a lot of damage if used incorrectly, they require user permission before overwriting or deleting a folder. The user controls the permission process using the Miscellaneous Settings dialog (Misc menu).
Writing to a Text File​
You can generate output text files from Igor procedures or from the command line in formats acceptable to other programs. To do this, you need to use the Open and Close operations and the fprintf operation and the wfprintf operation.
The following example illustrates how you could use these operations to create an output text file. Each operation is described in detail in following sections:
Function WriteFileDemo(pathName, fileName)
String pathName // Name of Igor symbolic variable (see Symbolic Paths)
String fileName // File name, partial path or full path
Variable refNum
Open/P=$pathName refNum as fileName // Create and open file
fprintf refNum, "wave1\twave2\twave3\r" // Write column headers
Wave wave1, wave2, wave3
wfprintf refNum, "" wave1, wave2, wave3 // Write wave data
Close refNum // Close file
Open and Close Operations​
You use the Open operation to open a file. For our purposes, the syntax of the Open operation is:
Open [/R/A/P=pathName/M=messageStr ] variableName [as "fileName"]
variableName is the name of a numeric variable. The Open operation puts a file reference number in that variable. You use the reference number to access the file after you've opened it.
A file specifications consists of a path (directions for finding a folder) and a file name. In the Open operation, you can specify the path in three ways:
Using a full path as the fileName parameter:
Open refNum as "hd:Data:Run123.dat"
Or using a symbolic path name and a file name:
Open/P=DataPath refNum as "Run123.dat"
Or using a symbolic path name and a partial path including the file name:
Open/P=HDPath refNum as ":Data:Run123.dat"
A symbolic path is a short name that refers to a folder on disk (see Symbolic Paths).
If you do not provide enough information to find the folder and file of interest, Igor displays a dialog which lets you select the file to open. If you supply sufficient information, Igor opens the file without displaying the dialog.
To open an existing file for reading, use the /R flag. To append new data to an existing file, use the /A flag. If you omit both of these flags and if the file already exists, you overwrite any data that is in the file.
If you open a file for writing (you don't use /R) then, if there exists a file with the specified name, Igor opens the file and overwrites the existing data in the file. If there is no file with the specified name, Igor creates a new file.
caution
If you're not careful you can inadvertently lose data using the Open operation by opening for writing without using the /A flag. To avoid this, use the /R (open for read) or /A (append) flags.
Wave Reference Functions​
It is common to write a user-defined function that operates on all of the waves in a data folder, on the waves displayed in a graph or table, or on a wave identified by a cursor in a graph. For these purposes, you need to use wave reference functions.
Wave reference functions are built-in Igor functions that return a reference that can be used in a user-defined function. Here is an example that works on the top graph. Cursors are assumed to be placed on a region of a trace in the graph.
Function WaveAverageBetweenCursors()
WAVE/Z w = CsrWaveRef(A)
if (!WaveExists(w)) // Cursor is not on any wave.
return NaN
Variable xA = xcsr(A)
Variable xB = xcsr(B)
Variable avg = mean(w, xA, xB)
return avg
CsrWaveRef returns a wave reference that identifies the wave a cursor is on.
An older function, CsrWave, returns the name of the wave the cursor is on. It would be tempting to use this to determine the wave the cursor is on, but it would be incorrect. The name of a wave by itself does not uniquely identify a wave because it does not tell us in what data folder the wave resides. For this reason, we usually need to use the wave reference function CsrWaveRef instead of CsrWave.
This example uses a wave reference function to operate on the waves displayed in a graph:
Function SmoothWavesInGraph()
String list = TraceNameList("", ";", 1)
String traceName
Variable index = 0
do
traceName = StringFromList(index, list)
if (strlen(traceName) == 0)
break // No more traces.
WAVE w = TraceNameToWaveRef("", traceName)
Smooth 5, w
index += 1
while(1)
Use WaveRefIndexedDFR to iterate over the waves in a given data folder.
Here are the wave reference functions.
FunctionComment
CsrWaveRefReturns a reference to the Y wave to which a cursor is attached.
CsrXWaveRefReturns a reference to the X wave when a cursor is attached to an XY pair.
WaveRefIndexedDFRReturns a reference to a wave in the specified data folder.
WaveRefIndexedReturns a reference to a wave in a graph or table or to a wave in the current data folder.
XWaveRefFromTraceReturns a reference to an X wave in a graph. Used with the output of TraceNameList.
ContourNameToWaveRefReturns a reference to a wave displayed as a contour plot. Used with the output of ContourNameList.
ImageNameToWaveRefReturns a reference to a wave displayed as an image. Used with the output of ImageNameList.
TraceNameToWaveRefReturns a reference to a wave displayed as a waveform or as the Y wave of an XY pair in a graph. Used with the output of TraceNameList.
TagWaveRefReturns a reference to a wave to which a tag is attached in a graph. Used in creating a smart tag.
WaveRefsEqualReturns the truth two wave references are the same.
WaveRefWaveToListReturns a semicolon-separated string list containing the full or partial path to the wave referenced by each element of the input wave reference wave.
ListToWaveRefWaveReturns a free wave containing a wave reference for each of the waves in the semicolon-separated input string list.
This simple example illustrates the use of the CsrWaveRef wave reference function:
Function/WAVE CursorAWave()
return w
Function DemoCursorAWave()
WAVE/Z w = CursorAWave()
if (WaveExists(w)==0)
Print "oops: no wave"
Printf "Cursor A is on the wave '%s'\r", NameOfWave(w)
Processing Lists of Waves​
Igor users often want to use a string list of waves in places where Igor is looking for just the name of a single wave. For example, they would like to do this:
Display "wave0;wave1;wave2"
or, more generally:
Function DisplayListOfWaves(list)
String list // e.g., "wave0;wave1;wave2"
Display $list
Unfortunately, Igor can't handle this. However, there are techniques for achieving the same result.
Graphing a List of Waves​
This example illustrates the basic technique for processing a list of waves.
Function DisplayWaveList(list)
String list // A semicolon-separated list.
Variable index = 0
do
// Get the next wave name
String name = StringFromList(index, list)
if (strlen(name) == 0)
break // Ran out of waves
Wave w = $name
if (index == 0) // Is this the first wave?
Display w
AppendToGraph w
index += 1
while (1) // Loop until break above
To make a graph of all of the waves in the current data folder, you could execute
DisplayWaveList(WaveList("*", ";", ""))
Operating On The Traces In A Graph​
In a previous section, we showed an example that operates on the waves displayed in a graph. It used a wave reference function, TraceNameToWaveRef. If you want to write a function that operates on traces in a graph, you would not use wave reference functions. That's because Igor operations that operate on traces expect trace names, not wave references. For example:
Function GrayOutTracesInGraph()
Variable index = 0
do
String traceName = StringFromList(index, list)
// WRONG: ModifyGraph expects a trace name and
// w is not a trace name
ModifyGraph rgb(w)=(50000,50000,50000)
// RIGHT
ModifyGraph rgb($traceName)=(50000,50000,50000)
index += 1
while(1)
Using a Fixed-Length List​
In the previous examples, the number of waves in the list was unimportant and all of the waves in the list served the same purpose. In this example, the list has a fixed number of waves and each wave has a different purpose.
Function DoLineFit(list)
String list // List of waves names: source, weight
// Pick out the expected wave names
String sourceStr = StringFromList(0, list)
Wave source = $sourceStr
String weightStr = StringFromList(2, list)
Wave weight = $weightStr
CurveFit line source /D /W=weight
You could invoke this function as follows:
DoLineFit("wave0;wave1;")
For most purposes, it is better to design the function to take wave reference parameters rather than a string list.
Operating On Qualified Waves​
This example illustrates how to operate on waves that match a certain criterion. It is broken into two functions — one that creates the list of qualified waves and a second that operates on them. This organization gives us a general purpose routine (ListOfMatrices) that we would not have if we wrote the whole thing as one function.
Function/S ListOfMatrices()
String list = ""
Variable index=0
do
WAVE/Z w=WaveRefIndexedDFR(:,index) // Get next wave.
if (WaveExists(w) == 0)
break // No more waves.
if (WaveDims(w) == 2)
// Found matrix. Add to list with separator.
list += NameOfWave(w) + ";"
index += 1
while(1) // Loop till break above.
return list
Function ChooseAndDisplayMatrix()
String theList = ListOfMatrices()
String theMatrix
Prompt theMatrix, "Matrix to display:", popup theList
DoPrompt "Display Matrix", theMatrix
if (V_Flag != 0)
return -1
WAVE m = $theMatrix
NewImage m
In the preceding example, we needed a list of wave names in a string to use in a Prompt statement. More often we want a list of wave references on which to operate. The next example illustrates how to do this using a general purpose routine that returns a list of wave references in a free wave:
// Returns a free wave containing wave references for each 2D wave in the current data folder
Function/WAVE GetMatrixWavesInCDF()
Variable numWavesInCDF = CountObjects(":", 1)
Make/FREE/WAVE/N=(numWavesInCDF) list
Variable numMatrixWaves = 0
Variable i
for(i=0; i<numWavesInCDF; i+=1)
WAVE w = WaveRefIndexedDFR(:,i)
Variable numDimensions = WaveDims(w)
if (numDimensions == 2)
list[numMatrixWaves] = w
numMatrixWaves += 1
Redimension/N=(numMatrixWaves) list
return list // Ownership of the wave is passed to the calling routine
Function DemoMatrixWaveList()
Wave/WAVE freeList = GetMatrixWavesInCDF() // We now own the freeList wave
Variable numMatrixWaves = numpnts(freeList)
Printf "Number of matrix waves in current data folder: %d\r", numMatrixWaves
Variable i
for(i=0; i<numMatrixWaves; i+=1)
Wave w = freeList[i]
String name = NameOfWave(w)
name = PossiblyQuoteName(name)
Printf "Wave %d: %s\r", i, name
// freeList is automatically killed when the function returns
The ExecuteCmdOnList Function​
The ExecuteCmdOnList function is implemented by a WaveMetrics procedure file and executes any command for each wave in the list. For example, the following commands do a WaveStats operation on each wave.
Make wave0=gnoise(1), wave1=gnoise(10), wave2=gnoise(100)
ExecuteCmdOnList("WaveStats %s", "wave0;wave1;wave2;")
The ExecuteCmdOnList function is supplied in the "Execute Cmd On List" procedure file. See The Include Statement for instructions on including a procedure file.
This technique is on the kludgy side. If you can achieve your goal in a more straightforward fashion without heroic efforts, you should use regular programming techniques.
The Execute Operation​
Execute is a built-in operation that executes a string expression as if you had typed it into the command line. The main purpose of Execute is to allow you to get around the restrictions on calling macros and external operations from user functions.
We try to avoid using Execute because it makes code obscure and difficult to debug. If you can write a procedure without Execute, do it. However, there are some cases where using Execute can save pages of code or achieve something that would otherwise be impossible. For example, the TileWindow operation cannot be directly called from a user-defined function and therefore must be called using Execute.
It is a good idea to compose the command to be executed in a local string variable and then pass that string to the Execute operation. Use this to print the string to the history for debugging. For example:
Function DemoExecute(list)
String list // Semicolon-separated list of names of windows to tile
list = ReplaceString(";", list, ",") // We need commas for TileWindows command
list = RemoveEnding(list, ",") // Remove trailing comma, if any
String cmd
sprintf cmd, "TileWindows %s", list
Print cmd // For debugging only
Execute cmd
When you use Execute, you must be especially careful in the handling of wave names. See Programming with Liberal Names for details.
When Execute runs, it is as if you typed a command in the command line. Local variables in macros and functions are not accessible. The example in Calling an External Operation From a User-Defined Function shows how to use the sprintf operation to solve this problem.
Using a Macro From a User-Defined Function​
A macro cannot be called directly from a user function. To do so, we must use Execute. This is a trivial example for which we would normally not resort to Execute but which clearly illustrates the technique.
Function Example()
Make wave0=enoise(1)
Variable/G V_avg // Create a global
Execute "MyMacro(\"wave0\")" // Invokes MyMacro("wave0")
return V_avg
Macro MyMacro(wv)
String wv
WaveStats $wv // Sets global V_avg and 9 other local vars
Execute does not supply good error messages. If the macro generates an error, you may get a cryptic message. Therefore, debug the macro before you call it with the Execute operation.
Calling an External Operation From a User-Defined Function​
Prior to Igor Pro 5, external operations could not be called directly from user-defined functions and had to be called via Execute. Now it is possible to write an external operation so that it can be called directly. However, very old XOPs that have not been updated still need to be called through Execute. This example shows how to do it.
If you attempt to directly use an external operation which does not support it, Igor displays an error dialog telling you to use Execute for that operation.
The external operation in this case is VDTWrite which sends text to the serial port. It is implemented by the VDT XOP (no longer shipped as of Igor 7).
Function SetupVoltmeter(range)
Variable range // .1, .2, .5, 1, 2, 5 or 10 volts
String voltmeterCmd
sprintf voltmeterCmd, "DVM volts=%g", range
String vdtCmd
sprintf vdtCmd "VDTWrite \"%s\"\r\n", voltmeterCmd
Execute vdtCmd
In this case, we are sending the command to a voltmeter that expects something like:
DVM volts=.2<CR><LF>
to set the voltmeter to the 0.2 volt range.
The parameter that we send to the Execute operation is:
VDTWrite "DVM volts=.2\r\n"
The backslashes used in the second sprintf call insert two quotation marks, a carriage return, and a linefeed in the command about to be executed.
A newer VDT2 XOP exists which includes external operations that can be directly called from user-functions. Thus, new programming should use the VDT2 XOP and will not need to use Execute.
Other Uses of Execute​
Execute can also accept as an argument a string variable containing commands that are algorithmically constructed. Here is a simple example:
Function Fit(w, fitType)
WAVE w // Source wave
String fitType // One of the built-in Igor fit types
name = PossiblyQuoteName(name) // Liberal names need quotes
String cmd
sprintf cmd, "CurveFit %s %s", fitType, name
Execute cmd
Use this function to do any of the built-in fits on the specified wave. Without using the Execute operation, we would have to write it as follows:
strswitch(fitType)
case "line":
CurveFit line w
break
case "exp":
CurveFit exp w
break
<and so on for each fit type>
endswitch
Note the use of sprintf to prepare the string containing the command to be executed. The following would not work because when Execute runs, local variables and parameters are not accessible:
Execute "CurveFit fitType name"
Deferred Execution Using the Operation Queue​
It is sometimes necessary to execute a command after the current function has finished. This is done using the Execute/P operation. For details, see Operation Queue.
Procedures and Preferences​
As explained under Preferences, Igor allows you to set many preferences. Most of the preferences control the style of new objects, including new graphs, traces and axes added to graphs, new tables, columns added to tables, and so on.
Preferences are usually used only for manual "point-and-click" operation. We usually don't want preferences to affect the behavior of procedures. The reason for this is that we want a procedure to do the same thing no matter who runs it. Also, we want it to do the same thing tomorrow as it does today. If we allowed preferences to take effect during procedure execution, a change in preferences could change the effect of a procedure, making it unpredictable.
By default, preferences do not take effect during procedure execution. If you want to override the default behavior, you can use the Preferences operation. From within a procedure, you can execute Preferences 1 to turn preferences on. This affects the procedure and any subroutines that it calls. It stays in effect until you execute Preferences 0.
When a macro ends, the state of preferences reverts to what it was when that macro started. If you change the preference setting within a function, the preferences state does not revert when that function ends. You must turn preferences on, save the old preferences state, execute Igor operations, and then restore the preferences state. For example:
Function DisplayWithPreferences(w)
Wave w
Variable oldPrefState
Preferences 1 // Turn preferences on
oldPrefState = V_Flag // Save the old state
Display w // Create graph using preferences
Preferences oldPrefState // Restore old prefs state
Experiment Initialization Procedures​
When Igor loads an experiment, it checks to see if there are any commands in the procedure window before the first macro, function or menu declaration. If there are such commands Igor executes them. This provides a way for you to initialize things. These initialization commands can invoke procedures that are declared later in the procedure window.
Also see BeforeFileOpenHook and IgorStartOrNewHook for other initialization methods.
Procedure Subtypes​
A procedure subtype tells Igor the purpose for which a particular procedure is intended. This allows Igor to present the procedure in the appropriate menu. For example, the Graph subtype tells Igor to put a procedure in the Graph Macros submenu of the Windows menu.
Window Graph0() : Graph
PauseUpdate; Silent 1 // building window...
Display/W=(5,42,400,250) wave0,wave1,wave2
<more commands>
When Igor automatically creates a procedure, for example when you close and save a graph, it uses the appropriate subtype. When you create a curve fitting function using the Curve Fitting dialog, the dialog automatically uses the FitFunc subtype. You usually don't need to use subtypes for procedures that you write.
This table shows the available subtypes and how they are used.
SubtypeEffect
GraphDisplayed in Graph Macros submenu. Available for macros only.
GraphStyleDisplayed in Graph Macros submenu and in Style pop-up menu in New Graph dialog. Available for macros only.
GraphMarqueeDisplayed in graph marquee. Available for macros and functions. This keyword is no longer recommended. See Marquee Menu as Input Device for details.
CursorStyleDisplayed in Style Function submenu of cursor pop-up menu in graph info pane. Available for functions only.
DrawUserShapeMarks a function as suitable for drawing a user-defined drawing object. See DrawUserShape. Available for functions only.
GridStyleDisplayed in Grid→Style submenu of mover pop-up menu in drawing tool palette. Available for functions only.
TableDisplayed in Table Macros submenu. Available for macros only.
TableStyleDisplayed in Table Macros submenu and in Style pop-up menu in New Table dialog. Available for macros only.
LayoutDisplayed in Layout Macros submenu. Available for macros only.
LayoutStyleDisplayed in Layout Macros submenu and in Style pop-up menu in New Layout dialog. Available for macros only.
LayoutMarqueeDisplayed in layout marquee. Available for macros and functions. This keyword is no longer recommended. See Marquee Menu as Input Device for details.
ListBoxControlDisplayed in Procedure pop-up menu in ListBox Control dialog. Available for macros and functions.
PanelDisplayed in Panel Macros submenu. Available for macros only.
GizmoPlotDisplayed in Other Macros submenu. Available for macros only.
CameraWindowDisplayed in Other Macros submenu. Available for macros only.
FitFuncDisplayed in Function pop-up menu in Curve Fitting dialog. Available for functions only.
ButtonControlDisplayed in Procedure pop-up menu in Button Control dialog. Available for macros and functions.
CheckBoxControlDisplayed in Procedure pop-up menu in Checkbox Control dialog. Available for macros and functions.
PopupMenuControlDisplayed in Procedure pop-up menu in PopupMenu Control dialog. Available for macros and functions.
SetVariableControlDisplayed in Procedure pop-up menu in SetVariable Control dialog. Available for macros and functions.
SliderControlDisplayed in Procedure pop-up menu in Slider Control dialog. Available for macros and functions.
TabControlDisplayed in Procedure pop-up menu in Tab Control dialog. Available for macros and functions.
CDFFuncDisplayed in the Kolmogorov-Smirnov Test dialog. See StatsKSTest for details. Available for functions only.
Memory Considerations​
Running out of memory is usually not an issue unless you load gigabytes of data into memory at one time. If memory becomes fragmented, you may get unexpected out-of-memory errors. This is much more likely in IGOR32 than IGOR64.
On most systems, IGOR32 can access 4 GB of virtual memory. The limits for IGOR64 are much higher and depend on your operating system.
See Memory Management for further information.
Wave Reference Counting​
Igor uses reference counting to determine when a wave is no longer referenced anywhere and memory can be safely deallocated.
Because memory is not deallocated until all references to a given wave are gone, memory may not be freed when you think. Consider the function:
Function myfunc()
Make/N=10E6 bigwave
// do stuff
FunctionThatKillsBigwave()
// do more stuff
The memory allocated for bigwave is not deallocated until the function returns because Make creates an automatic wave reference variable which, by default, exists until the function returns. To free memory before the function returns, use WAVEClear:
Function myfunc()
Make/N=10E6 bigwave
// do stuff
WAVEClear bigwave
// do more stuff
The WAVEClear command takes a list of WAVE reference variables and stores NULL into them. It is the same as:
WAVE/Z wavref= $""
Detecting Wave Leaks​
Igor Pro 9.00 introduced two ways to detect wave leaks: IgorInfo(16) and Wave Tracking. These are tools for advanced Igor programmers. Wave tracking is discussed in the next section.
IgorInfo(16) is a quick and lightweight way to detect possible wave leaks. Unlike wave tracking, IgorInfo(16) can be used independently by different procedure packages without interference among them.
IgorInfo(16) returns the total number of waves of all kinds in existence at any given time. You can use it like this:
Function DetectWaveLeaks()
int originalNumberOfWaves = str2num(IgorInfo(16))
// <Do a lot of processing that you suspect might leak waves>
int newNumberOfWaves = str2num(IgorInfo(16))
int changeInNumberOfWaves = newNumberOfWaves - originalNumberOfWaves
if (changeInNumberOfWaves > 0)
Beep
Printf "Possible leak: Number of waves changed by %d\r", changeInNumberOfWaves
IgorInfo(16) may sometimes create false positives. For example, the Igor debugger and the Igor Data Browser sometimes create hidden waves for their internal use. An example is the debugger if you choose Show Waves in Graph from the Local Waves, Strings, and SVARs popup menu. This can cause a discrepancy in the number of waves at the start and end of a function but it is not a real leak as Igor will eventually reuse or kill the wave.
Because of the possibility of false positives, you should consider a discrepancy such as detected by the DetectWaveLeaks function above evidence of a possible leak only. To confirm the leak, rerun the function without the use of the debugger or any other user-interface interactions. If it still appears to be a leak, use Wave Tracking to investigate the cause.
Wave Tracking​
The WaveTracking operation is a tool for detecting and investigating wave leaks. WaveTracking was introduced in Igor Pro 9.00.
A fast and lightweight complement to wave tracking is IgorInfo(16). For details, see Detecting Wave Leaks above.
Igor waves fall into three categories and each category can be tracked separately: global, free, and local.
Global waves are waves stored in the main data folder hierarchy, i.e., in the root data folder or one of its descendants. These are the usual waves that you work with on a regular basis. They are global in the sense that they are persistent (you must explicitly kill them) and are accessible from any context (any function or from the command line) at any time.
Free waves are waves that are not contained in any data folder. You create them in user-defined functions via the NewFreeWave function, the Make/FREE operation, or other operations that support the /FREE flag. You use a wave reference variable to access a free wave (see Wave References). When the last wave reference for a given free wave has gone out of scope or is cleared by WaveClear, Igor automatically kills the wave.
Local waves are waves that are stored in a free data folder or a descendant of a free data folder. They are local in the sense that they are automatically killed and are accessible only if you hold a data folder reference for the containing data folder or its ancestor.
Local waves become free waves when the containing data folder is destroyed if a wave reference still remains. See Free Wave Lifetime and Free Data Folder Lifetime.
The topic Free Wave Leaks illustrates how you can permanently leak a free wave. After they are leaked, there is no way to access them, so the only way to recover the memory is to restart Igor. You can use the WaveTracking operation to detect and investigate such leaks.
Sometimes you may have a backlog of global waves that were created for temporary use but not deleted. These waves are stored in memory and on disk when you save an experiment. You can use the WaveTracking operation to identify and clean up the backlog.
The WaveTracking operation allows you to keep track of the number of waves created but not killed over a given period of time and to get information on those waves. When Igor starts up, tracking is turned off. You must turn it on, as illustrated below, before you run code that you suspect is causing a problem.
WaveTracking provides two modes. Counter mode tells you the number waves of a given category created minus the number killed since counting started. Tracker mode keeps a list of every wave created but not yet been killed since tracking started. Tracker mode adds to the time it takes to create and kill waves, so counter mode is useful for detecting leaks while tracker mode is useful for investigating leaks once they are detected.
To illustrate, we will use the Leaks function defined here. It demonstrates how free wave leaks can occur and in the process leaks two free waves.
Function/WAVE GenerateFree()
return NewFreeWave(2,3)
Function Leaks()
Duplicate/O GenerateFree(),dummy // This leaks
Variable maxVal = WaveMax(GenerateFree()) // So does this
If you want to follow along with the example, copy these functions to your procedure window and then close it.
First we turn on the free wave counter:
WaveTracking/FREE counter
Turning wave tracking on resets the counter even if it was already on.
This command demonstrates that no free waves were leaked since counting was turned on:
WaveTracking/FREE count; Print V_numWaves
0
Now we run the Leaks function and check the count again:
Leaks(); WaveTracking/FREE count; Print V_numWaves
2
After running the Leaks function, there are two free waves that did not exist before. There is no way at this point to get rid of them, but at least now you know about it, and perhaps you can figure out what leaked them.
The counter tracking mode does a simple increment when a wave of a given category is created, and a decrement when a wave is killed. If you kill a wave that was created before the tracking counter was started, the count can go negative.
Naturally the Leaks function is much less complex than typical code. It can be quite difficult to figure out where the leaked waves are created. To help with that, you can use the tracker mode and give your free waves names. If you want to follow along with the example, copy these functions to your procedure window and then close it:
Function/WAVE GenerateFreeNamed()
return NewFreeWave(2,3, "MadeByGenerateFree")
Function LeaksNamed()
Duplicate/O GenerateFreeNamed(),dummy // This leaks
Variable maxVal = WaveMax(GenerateFreeNamed()) // So does this
We now run LeaksNamed with WaveTracking in tracker mode:
WaveTracking/FREE tracker
LeaksNamed()
WaveTracking/FREE dump
Since tracking began, 2 free wave(s) have been created and not killed.
Wave 'MadeByGenerateFree'; refcount: 0
This time, instead of printing the count of free waves, we used "dump" to get a list of the free waves. The dump keyword prints a list in the history area showing the name of each free wave and its reference count. The names tell you that those were waves made by the GenerateFreeNamed function.
In the example in Wave Reference MultiThread Example, a WAVE wave, named ww, is created at the start of the Demo function. ww is filled with free waves by the MultiThread call. At the end of the function, KillWaves is called to kill ww which automatically kills the free waves. If you omitted the KillWaves call at the end, this would create a large leak. You could investigate it using WaveTracking/FREE tracker and WaveTracking/FREE dump.
Creating Igor Extensions​
Igor includes a feature that allows a C or C++ programmer to extend its capabilities. Using Microsoft Visual C++, a programmer can add command line operations and functions to Igor. These are called external operations and external functions. Experienced programmers can also add menu items, dialogs and windows.
A file containing external operations or external functions is called an "XOP file" or "XOP" (pronounced "ex-op") for short.
Here are some things for which you might want to write an XOP:
  • To do number-crunching on waves.
  • To import data from a file format that Igor does not support.
  • To acquire data directly into Igor waves.
  • To communicate with a remote computer, instrument or database.
The main reasons for writing something as an XOP instead of writing it as an Igor procedure are:
  • It needs to be blazing fast.
  • You already have a lot of C code that you want to reuse.
  • You need to call drivers for data acquisition.
  • It requires programming techniques that Igor doesn't support.
  • You want to add your own dialogs or windows.
Writing an XOP that does number-crunching is considerably easier than writing a stand-alone program. You don't need to know anything about Windows APIs.
If you are a C or C++ programmer and would like to extend Igor with your own XOP, you need to purchase the Igor External Operations Toolkit from WaveMetrics. This toolkit contains documentation on writing XOPs as well as the source code for several WaveMetrics sample XOPs. It supplies a large library of routines that enable communication between Igor and the external code. You will also need the a recent version of Xcode, or Microsoft Visual C++.
