Skip to main content
Procedure Windows
This section explains what procedure windows are, how they are created and organized, and how you work with them. It does not cover programming. See Programming Overview for an introduction.
A procedure window is where Igor procedures are stored. Igor procedures are the macros, functions and menu definitions that you create or that Igor creates automatically for you.
The content of a procedure window is stored in a procedure file. In the case of a packed Igor experiment, the procedure file is packed into the experiment file.
Types of Procedure Files​
There are four types of procedure files:
  • The experiment procedure file, displayed in the built-in procedure window
  • Global procedure files, displayed in auxiliary procedure windows
  • Shared procedure files, displayed in auxiliary procedure windows
  • Auxiliary experiment procedure files, displayed in auxiliary procedure windows
The built-in procedure window holds the experiment-specific procedures of the currently open experiment. This is the only procedure window that beginning or casual Igor users may need.
All other procedure windows are called auxiliary to distinguish them from the built-in procedure window. You create an auxiliary procedure window using Windows→New→Procedure. You can then save it to a standalone file, using File→Save Procedure As, or allow Igor to save it as part of the current experiment.
A global procedure file contains procedures that you might want to use in any experiment. It must be saved as a standalone file in the "Igor Procedures" folder of your Igor Pro User Files folder. Procedure files in "Igor Procedures" are automatically opened by Igor at startup and left open until Igor quits. This is the easiest way to make procedures available to multiple experiments.
A shared procedure file contains procedures that you want to use in more than one experiment but that you don't want to be open all of the time. It must be saved as a standalone file. The recommended location is the "User Procedures" folder of your Igor Pro User Files folder.
An auxiliary experiment procedure file contains procedures that you want to use in a single experiment but want to keep separate from the built-in procedure window for organizational purposes. In a packed experiment it is saved as a packed file within the experiment file. In an unpacked experiment it is saved as a standalone file in the experiment folder.
Working with the Built-in Procedure Window​
Procedures that are specific to the current experiment are usually stored in the built-in procedure window. Also, when Igor automatically generates procedures, it stores them in the built-in procedure window.
To show the built-in procedure window, choose Windows→Procedure Windows→Procedure Window or press Ctrl+M. To hide it, click the close button or press Ctrl+W.
To create a procedure, just type it into the procedure window.
The contents of the built-in procedure window are automatically stored when you save the current Igor experiment. For unpacked experiments, the contents are stored in a file called "procedure" in the experiment folder. For packed experiments, the contents are stored in the packed experiment file. When you open an experiment Igor loads its procedures back into the built-in procedure window.
Compiling the Procedures​
When you modify the text in the procedure window, you will notice that a Compile button appears at the bottom of the window.
Clicking the Compile button scans the procedure window looking for macros, functions and menu definitions. Igor compiles user-defined functions, generating low-level instructions that can be executed quickly.
Igor also compiles the code in the procedure window if you select Compile from the Macros menu or if you activate any window other than a procedure or help window.
Templates Pop-Up Menu​
The Templates pop-up menu lists all of the built-in and external operations and functions in alphabetical order and also lists the common flow control structures.
If you choose an item from the menu, Igor inserts the corresponding template in the procedure window.
If you select, click in, or click after a recognized operation, function or flow-control keyword in the procedure window, two additional items are listed at the top of the menu. The first item inserts a template and the second takes you to help.
In addition to templates, procedure windows support Command Completion.
Procedure Navigation Bar​
The procedure navigation bar appears at the top of each procedure window. It consists of a menu and a settings button. The menu provides a quick way to find procedures in the active procedure window.
Certain syntax errors prevent Igor from parsing procedures. In that case, the menu shows no procedures.
You can hide the navigation bar by choosing Misc→Miscellaneous Settings, selecting the Text Editing section, and unchecking the Show Navigation Bar checkbox.
Write-Protect Icon​
Procedure windows have a write-enable/write-protect icon which appears in the lower-left corner of the window and resembles a pencil. If you click this icon, Igor Pro displays an icon indicating that the procedure window is write-protected. The main purpose of this is to prevent accidental alteration of shared procedure files.
Igor opens included user procedure files for writing but turns on the write-protect icon so that you will get a warning if you attempt to change them. If you do want to change them, simply click the write-protect icon to turn protection off. You can turn this default write-protection feature off via the Text Editing section of the Miscellaneous Settings dialog.
If a procedure file is opened for reading only, you will see a lock icon instead of the pencil icon. A file opened for read-only cannot be modified.
WaveMetrics procedures, in the WaveMetrics Procedures folder, are assumed to be the same for all Igor users and should be changed by WaveMetrics only. Therefore, Igor opens included WaveMetrics procedures for reading only.
Magnifier Icon​
You can magnify procedure text to make it more readable. See Text Magnification for details.
Creating Procedure Windows​
There are three ways to create procedures:
  • Automatically by Igor
  • Manually, when you type in a procedure window
  • Semiautomatically, when you use various dialogs
Igor offers to automatically create a window recreation macro when you close a target window. A window recreation macro is a procedure that can recreate a graph, table, page layout or control panel window. See Saving a Window as a Recreation Macro for details.
You can add procedures by merely typing them in a procedure window.
You can create user-defined controls in a graph or control panel. Each control has an optional action procedure that runs when the control is used. You can create a control and its corresponding action procedure using dialogs that you access through the Add Controls submenu in the Graph or Panel menus. These action procedures are initially stored in the built-in procedure window.
You can create user-defined curve fitting functions via the Curve Fitting dialog. These functions are initially stored in the built-in procedure window.
Creating New Procedure Files​
You create a new procedure file if you want to write procedures to be used in more than one experiment.
note
There is a risk in sharing procedure files among experiments. If you copy the experiment to another computer and forget to also copy the shared files, the experiment will not work on the other computer. See References to Files and Folders for further details.
If you do create a shared procedure file then you are responsible for copying the shared file when you copy an experiment that relies on it.
To create a new procedure file, choose Windows→New→Procedure. This creates a new procedure window. The procedure file is not created until you save the procedure window or save the experiment.
You can explicitly save the procedure window by choosing File→Save Procedure As or by closing it and choosing to save it in the resulting dialog. This saves the file as an auxiliary procedure file, separate from the experiment.
If you don't save the procedure window explicitly, Igor saves it as part of the current experiment the next time you save the experiment.
Opening an Auxiliary Procedure File​
You can open a procedure file using the File→Open File→Procedure menu item.
When you open a procedure file, Igor displays it in a new procedure window. The procedures in the window can be used in the current experiment. When you save the current experiment, Igor will save a reference to the shared procedure file in the experiment file. When you later open the experiment, Igor will reopen the procedure file.
For procedure files that you in from a large number of experiments, it is better to configure the files as a global procedure file. See Global Procedure Files.
For commonly used auxiliary files, it is better to use the include statement. See Including a Procedure File.
Showing Procedure Windows​
We usually show procedure windows when we are doing programming and hide them for normal use.
To show the built-in procedure window, choose Windows→Procedure Windows→Procedure Window or press Ctrl+M. To show auxiliary procedure windows, use the Windows→Procedure Windows submenu.
If you have more than one procedure window, you can cycle to the next procedure window by pressing Ctrl+Alt+M. Pressing Ctrl+Shift+Alt+M hides the active procedure window and shows the next one.
You can also show a procedure window by selecting a menu item added by that window while pressing Alt. This feature works only if the top window is a procedure window.
You can show all procedure windows and hide all procedure windows using the Windows→Show and Windows→Hide submenus.
Hiding and Killing Procedure Windows​
The built-in procedure window always exists as part of the current experiment. You can hide it by clicking the close button, pressing Ctrl+W or by choosing Hide from the Windows menu. You cannot kill it.
Auxiliary procedure files can be opened (added to the experiment), hidden and killed (removed from the experiment). This leads to a difference in behavior between auxiliary procedure windows and the built-in procedure window.
When you click the close button of an auxiliary procedure file, Igor presents the Close Procedure Window dialog to find out what you want to do.
If you just want to hide the window, you can press Shift while clicking the close button. This skips the dialog and just hides the window.
Killing a procedure window closes the window and removes it from the current experiment but does not delete or otherwise affect the procedure file with which the window was associated. If you have made changes or the procedure was not previously saved, you will be presented with the choice of saving the file before killing the procedure.
The Close item of the Windows menu and the equivalent, Ctrl+W, behave the same as the close button.
Saving All Standalone Procedure Files​
When a procedure window is active, you can save all modified standalone procedure files at once by choosing File→Save All Standalone Procedure Files. This saves only standalone procedure files. It does not save the built-in procedure window, packed procedure files, or procedure windows that were just created and never saved to disk; these are saved when you save the experiment.
Autosaving Standalone Procedure Files​
Igor can automatically save modified standalone procedure files. See Autosave for details.
Global Procedure Files​
Global procedure files contain procedures that you want to be available in all experiments. They differ from other procedure files in that Igor opens them automatically and never closes them. Configuring a procedure file as a global procedure file is the easiest way to make it widely available.
When Igor starts running, it searches "Igor Pro Folder/Igor Procedures" and "Igor Pro User Files/Igor Procedures" (see Igor Pro User Files for details), as well as subfolders, as well as files and folders referenced by shortcuts. Igor opens any procedure file that it finds during this search as a global procedure file.
You should save your global procedure files in "Igor Pro User Files/Igor Procedures". You can locate this folder by selecting Help→Show Igor Pro User Files.
Igor opens global procedure files with write-protection on since they presumably contain procedures that you have already debugged and which you don't want to inadvertently modify. If you do want to modify a global procedure file, click the write-protect icon (pencil in lower-left corner of the window). You can turn this default write-protection feature off via the Text Editing section of the Miscellaneous Settings dialog.
When you create a new experiment or open an existing one, Igor normally closes any open procedure files, but it leaves global procedure files open. You can explicitly close a global procedure window at any time and then you can manually reopen it. Igor will not automatically reopen it until the next time Igor is launched.
Although its procedures can be used by the current experiment, a global procedure file is not part of the current experiment. Therefore, Igor does not save a global procedure file or a reference to a global procedure file inside an experiment file.
note
There is a risk in using global procedure files. If you copy an experiment that relies on a global procedure file to another computer and forget to also copy the global procedure file, the experiment will not work on the other computer.
Saving Global Procedure Files​
If you modify a global procedure file, Igor will save it when you save the current experiment even though the global procedure file is not part of the current experiment. However, you might want to save the procedure file without saving the experiment. For this, use the File→Save Procedure menu item.
Shared Procedure Files​
You may develop procedures that you want to use in several but not all of your experiments. You can facilitate this by creating a shared procedure file. This is a procedure file that you save in its own file, separate from any experiment. Such a file can be opened from any experiment.
There are two ways to open a shared procedure file from an experiment:
  • By explicitly opening it, using the File→Open File submenu or by double-clicking it or by drag-and-drop
  • By adding an include statement to your experiment procedure window
The include method is preferred and is described in detail under Including a Procedure File.
When Igor encounters an include statement, it searches for the included file in "Igor Pro Folder/User Procedures" and in "Igor Pro User Files/User Procedures" (see Igor Pro User Files for details). The Igor Pro User Files folder is the recommended place for storing user files. You can locate it by choosing Help→Show Igor Pro User Files.
You can store your shared procedure procedure file directly in "Igor Pro User Files/User Procedures" or you can store it elsewhere and put a shortcut for it in "Igor Pro User Files/User Procedures". If you have many shared procedure files you can put them all in your own folder and put a shortcut for the folder in "Igor Pro User Files/User Procedures".
When you explicitly open a procedure file using the Open File submenu, by double-clicking it, or by drag-and-drop, you are adding it to the current experiment. When you save the experiment, Igor saves a reference to the procedure file in the experiment file. When you close the experiment, Igor closes the procedure file. When you later reopen the experiment, Igor reopens the procedure file.
When you use an include statement, the included file is not considered part of the experiment but is still referenced by the experiment. Igor automatically opens the included file when it hits the include statement during procedure compilation.
note
There is a risk in sharing procedure files among experiments. If you copy the experiment to another computer and forget to also copy the shared files, the experiment will not work on the other computer. See References to Files and Folders for more explanation.
Saving Shared Procedure Files​
If you modify a shared procedure file, Igor saves it when you save the experiment that is sharing it. However, you might want to save the procedure file without saving the experiment. For this, use the File→Save Procedure menu item.
Including a Procedure File​
You can put an include statement in any procedure file. An include statement automatically opens another procedure file. This is the recommended way of accessing files that contain utility routines which you may want to use in several experiments. Using an include statement is preferable to opening a procedure file explicitly because it doesn't rely on the exact location of the file in the file system hierarchy.
Here is a typical include statement:
#include <MatrixToXYZ>
This automatically opens the MatrixToXYZ.ipf file supplied by WaveMetrics in "Igor Pro Folder/WaveMetrics Procedures/Data Manipulation". The angle brackets tell Igor to search file the "Igor Pro Folder/WaveMetrics Procedures" hierarchy for the named file.
To see what WaveMetrics procedure files are available, choose Help→Help Windows→WM Procedures Index.
You can include your own utility procedure files by using double-quotes instead of the angle-brackets shown above:
#include "Your Procedure File"
The double-quotes tell Igor to search the "Igor Pro Folder/User Procedures" and "Igor Pro User Files/User Procedures" hierarchies (see Igor Pro User Files for details) for the named file. Igor searches those folders and subfolders and files or folders referenced by shortcuts in those folders.
These are the two main variations on the include statement. For details on less frequently used variations, see The Include Statement.
Included procedure files are not considered part of the experiment but are automatically opened by Igor when it compiles the experiment's procedures.
To prevent accidental alteration of an included procedure file, Igor opens it either write-protected (User Procedures) or read-only (WaveMetrics Procedures). See Write-Protect Icon.
A #include statement must omit the file's ".ipf" extension:
#include <Strings as Lists> // RIGHT.
#include <Strings as Lists.ipf> // WRONG.
Creating Packages​
A package is a set of procedure files, help files and other support files that add significant functionality to Igor.
Igor comes pre-configured with numerous WaveMetrics packages accessed through the Data→Packages, Analysis→Packages, Misc→Packages, Windows→New→Packages and Graph→Packages submenus as well as others.
Intermediate to advanced programmers can create their own packages. See Packages for details.
Invisible Procedure Files​
If you create a package of Igor procedures to be used by regular Igor users (as opposed to programmers), you may want to hide the procedures to reduce clutter or to eliminate the possibility that they might inadvertently change them. You can do this by creating invisible procedure files.
Invisible procedure files are omitted from Igor's Procedure Windows submenu which appears in the Windows menu. This keeps them out of the way of regular users.
There are three ways to make a procedure file invisible. In order of difficulty they are:
  • Using the #pragma hide compiler directive
  • Using an independent module
  • Using the operating-system-supplied file visibility property
Invisible Procedure Files Using #pragma hide​
You can make a procedure file invisible by inserting this compiler directive in the file:
#pragma hide=1
This prevents the procedure window from being listed in the Windows→Procedures submenu. Procedures windows that include this compiler directive become invisible on the next compile.
You can make these windows visible during development by executing:
SetIgorOption IndependentModuleDev=1
and return them to invisible by executing:
SetIgorOption IndependentModuleDev=0
You must force a compile for this to take effect.
Prior to Igor Pro 6.30 this feature worked for #included procedure files only, not for packed and standalone procedure files.
Invisible Procedure Files Using Independent Modules​
You can also make a set of procedure files invisible by making them an independent module. The independent module technique is more difficult to implement but has additional advantages. For details, see The IndependentModule Pragma.
Invisible Procedure Files Using The Files Visibility Property​
This section discusses making procedure files invisible by setting the operating-system-supplied file "visible" property.
note
This is an old technique that is no longer recommended. It may not be supported in future versions of Igor.
When Igor opens a procedure file, it asks the operating system if the file is hidden. We will use the term "invisible" to mean hidden.
If the file is invisible, Igor makes the file inaccessible to the user. Igor checks the invisible property only when it opens the file. It does not pay attention to whether the property is changed while the file is open.
You create Igor procedures using normal visible procedure files, typically all in a folder or hierarchy of folders. When it comes time to ship to the end user, you set the files to be invisible. If you set a file to be invisible, you should also make it read-only.
You can use the SetFileFolderInfo operation to set the visibility and read-only properties of a file:
SetFileFolderInfo /INV=1 /RO=1 "<path to file>"
The file will be invisible in Igor the next time you open it, typically by opening an experiment or using a #include statement.
Merely setting the hidden property is not sufficient to actually hide the file. It is actually hidden only if the Hide Files of These Types radio button in the View Options dialog is turned on. You can access this dialog by opening a folder in the Windows desktop and choosing View→Options from the folder's menu bar. Although the hidden property does not guarantee that the file will be hidden in the Windows desktop, it does guarantee that it will be hidden from within Igor.
After the files are set to be invisible and read-only, if you want to edit them in Igor, you must close them (typically by closing the open experiment), set the files to be visible and read/write again, and then open them again.
Igor's behavior is changed in the following ways for a procedure file set to invisible:
  1. The window will not appear in the Windows→Procedure Windows menu.
  2. Procedures in the window will not appear in the contextual pop-up menu in other procedure windows (Right-click).
  3. If the user presses Alt while choosing the name of a procedure from a menu, Igor will do nothing rather than its normal behavior of displaying the procedure window.
  4. When cycling through procedure windows using Ctrl+Shift+Alt+M, Igor will omit the procedure window.
  5. The Button Control dialog, Pop-Up Menu Control dialog, and other control dialogs will not allow you to edit procedures in the invisible file.
  6. The Edit Procedure and Debug buttons will not appear in the Macro Execute Error dialog.
  7. If an error occurs in a function in the invisible file and the Debug On Error flag (Procedure menu) is on, the debugger will act as if Debug On Error were off.
  8. The debugger won't allow you to step into procedures in the invisible file.
  9. The ProcedureText and ProcedureVersion functions and DisplayProcedure operation will act as if procedures in the invisible file don't exist. The MacroList and FunctionList functions will, however work as usual.
  10. The GetIgorProcedure and SetIgorProcedure XOPSupport routines in the XOP Toolkit will act as if procedures in the invisible file don't exist. The GetIgorProcedureList function will, however work as usual.
Inserting Text into a Procedure Window​
On occasion, you may want to copy text from one procedure file to another. With the procedure window active, choose Edit→Insert File. This displays an Open File dialog in which you choose a file and then inserts its contents into the procedure window.
Adopting a Procedure File​
Adoption is a way for you to copy a procedure file into the current experiment and break the connection to its original file. The reason for doing this is to make the experiment self-contained so that, if you transfer it to another computer or send it to a colleague, all of the files needed to recreate the experiment are stored in the experiment itself.
To adopt a file, open its associated window and choose File→Adopt Window. This item is available only if the active window is a notebook or procedure file that is stored separate from the current experiment and the current experiment has been saved to disk.
If the current experiment is stored in packed form then, when you adopt a file, Igor does a save-as to a temporary file. When you subsequently save the experiment, the contents of the temporary file are stored in the packed experiment file.
If the current experiment is stored in unpacked form then, when you adopt a file, Igor does a save-as to the experiment's home folder. When you subsequently save the experiment, Igor updates the experiment's recreation procedures to open the new file in the home folder instead of the original file. If you adopt a file in an unpacked experiment and then you do not save the experiment, the new file will still exist in the home folder but the experiment's recreation procedures will still refer to the original file. Thus, you should normally save the experiment soon after adopting a file.
Adoption does not cause the original file to be deleted. You can delete it from the desktop if you want.
To "unadopt" a procedure file, choose Save Procedure File As from the File menu.
It is possible to do adopt multiple files at one time. For details see Adopt All.
Auto-Compiling​
If you modify a procedure window and then activate a non-procedure window other than a help window, Igor automatically compiles the procedures.
If you have a lot of procedures and compiling takes a long time, you may want to turn auto-compiling off. You can do this by deselecting the Auto-compile item in the Macros menu. This item appears only when the procedures need to be compiled (you have modified a procedure file or opened a new one). If you uncheck it, Igor will not auto-compile and compilation will be done only when you click the Compile button or choose Compile from the Macros menu.
Debugging Procedures​
Igor includes a symbolic debugger. This is described in The Debugger.
Finding Text​
To find text in the active window, choose Edit→Find or press Ctrl+F. This displays the Find bar and will automatically populate the Find bar with the text under the cursor. See Finding Text In The Active Window for details.
To search multiple windows for text, choose Edit→Find in Multiple Windows. See Finding Text In Multiple Windows for details.
After doing a find, you can search for the same text again by pressing Ctrl+G (Find Same in the Edit menu). You can search for the same text but in the reverse direction by pressing Shift+Ctrl+G.
You can search back and forth through a procedure window by repeatedly pressing Ctrl+G and Shift-Ctrl+G.
Replacing Text​
To replace text in the active window, choose Edit→Replace or press Ctrl+R. This displays the Find bar in replace mode. See Find and Replace for details.
To replace text in multiple windows, choose Edit→Find in Multiple Windows.
While replacing text is undoable, the potential for unintended and wide-ranging consequences is such that we recommend saving the file before doing a mass replace so you can revert-to-saved if necessary.
Another method for searching and replacing consists of repeating Command-G or Ctrl-G (Find) followed by Command-V or Ctrl-G (Paste). This has the virtue of allowing you to inspect each occurrence of the target text before replacing it.
Printing Procedure Text​
To print the active procedure window, first deselect all text and then choose File→Print Procedure Window.
To print part of the active procedure window, select the text you want to print and choose File→Print Procedure Selection.
Indentation​
We use indentation to indicate the structure of a procedure.
To make it easy to use the indentation conventions, Igor maintains indentation when you press Return or Enter in a procedure window. It automatically inserts enough tabs in the new line to have the same indentation as the previous line.
To indent more, as when going into the body of a loop, press Return or Enter and then Tab. To indent less, as when leaving the body of a loop, press Return or Enter and then Delete. When you don't want to change the level of indentation, just press Return.
Included in the Edit menu for Procedure windows, is the Adjust Indentation item, which adjusts indentation of all selected lines of text to match Igor standards. The Edit menu also contains Indent Left and Indent Right commands that add or remove indentation for all selected lines.
Procedure Window Document Settings​
The Document Settings dialog controls settings that affect the procedure window as a whole. You can summon it via the Procedure menu.
Igor does not store document settings for plain text files. When you open a procedure file, these settings are determined by preferences. You can capture preferences choosing Procedure→Capture Procedure Prefs.
Procedure Window Default Tabs​
The default tab width setting controls the location of tabs stops in procedure windows. You set this using the Document Settings dialog in the Procedure menu or using a DefaultTab pragma. In a procedure window the default tab width setting controls the location of all tab stops which affect indentation and alignment of comments.
Igor does not store document settings for procedure files, so your preferred default tab width settings apply to all procedure files subsequently opened unless they include a DefaultTab pragma.
Three modes are available: points, spaces, and mixed. In points mode, you specify the default tab width in units of points. In the Document Settings dialog, you can enter this setting in inches, centimeters, or points, but it is always stored as points. Prior to Igor Pro 9.00, this was the only mode available.
In spaces mode, you specify the default tab width in units of spaces.
In mixed mode, you specify the default tab width for procedure windows controlled by proportional fonts in units of points and for procedure windows controlled by monospace fonts in units of spaces.
Mixed mode is recommended for compatibility with other text editors which typically set default tab widths in units of spaces.
In Igor Pro 9.00 and later, when you create a new procedure window, Igor inserts a DefaultTab pragma statement, like this:
#pragma DefaultTab = {3,20,4} // Sets default tab width in Igor Pro 9 or later
The DefaultTab pragma is explained in the next section.
The DefaultTab Pragma For Procedure Files​
In Igor Pro 9.00 and later, you can specify default tab settings by entering a pragma statement in the procedure window, like this:
#pragma DefaultTab = {<mode>,<width in points>,<width in spaces>}
Older versions of Igor ignore this pragma.
The pragma is applied when the procedure file is compiled. It helps keep aligned comments aligned when you share the procedure file with another Igor user or if you change the font, text size, or magnification of the procedure window.
The DefaultTab pragma, if present, sets the default tab width parameters the same as if you set them in the Document Settings dialog. <mode> is 1 for points mode, 2 for spaces mode, and 3 for mixed mode. Specifying the default tab width in spaces keeps comments in procedure files that you share with others aligned so long as the other users use a proportional font for procedure files. The recommended pragma is:
When you create a new procedure window, Igor inserts this DefaultTab statement in the new window. It overrides your default tab width preferences and specifies mixed mode (3) with the default tab width for proportional fonts set to 20 points and the default tab width for monospace fonts set to 4 spaces. Most people use a monospace font for procedure windows, in which case the default tab width is 4 spaces. If you share the procedure file with other users, this pragma increases the likelihood that aligned comments will remain aligned.
You can remove or edit the automatically inserted DefaultTab pragma. However, we recommend that you leave it as is.
We also recommend that you manually add this pragma to existing procedure files. You will then need to re-align comments.
Procedure Window Text Format Settings​
You can specify the font, text size, style and color using items in the Procedure menu. Since procedure windows are always plain text windows (as opposed to notebooks, which can be formatted text) these text settings are the same for all characters in the window.
Igor does not store text format settings (font, size, style, etc.) for plain text files. When you open a procedure file, these settings are determined by preferences. You can capture preferences choosing Procedure→Capture Procedure Prefs.
Syntax Coloring​
Procedure window and the command window colorize comments, literal strings, flow control, and other syntax elements. The colors for the various elements can be adjusted in two ways:
The first is from the Miscellaneous Settings dialog. Select the Text Editing category and then select the Color tab.
The second is by executing the following SetIgorOption colorize commands:
SetIgorOption colorize,doColorize=<1 or 0> // Turn all colorize on or off
SetIgorOption colorize,OpsColorized=<1 or 0> // Turn operation keyword colorization on or off
SetIgorOption colorize,BIFuncsColorized=<1 or 0> // Turn built-in function keyword colorization on or off
SetIgorOption colorize,keywordColor=(r,g,b[,a]) // Color for language keywords
SetIgorOption colorize,commentColor=(r,g,b[,a]) // Color for comments
SetIgorOption colorize,stringColor=(r,g,b[,a]) // Color for strings
SetIgorOption colorize,operationColor=(r,g,b[,a]) // Color for operation keywords
SetIgorOption colorize,functionColor=(r,g,b[,a]) // Color for built-in function keywords
SetIgorOption colorize,poundColor=(r,g,b[,a]) // Color for #keywords such as #pragma
SetIgorOption colorize,UserFuncsColorized=1 // Turn colorizing on for user-defined functions
SetIgorOption colorize,userFunctionColor=(r,g,b[,a]) // Color for user-defined functions
SetIgorOption colorize,SpecialFuncsColorized=1 // Turn colorizing on for special operations (MatrixOP and APMath)
SetIgorOption colorize,specialFunctionColor=(r,g,b[,a]) // Color for special operations (MatrixOP and APMath)
Values for r, g, b and the optional alpha range from 0 to 65535. Alpha defaults to 65535 (opaque).
Changes to the syntax coloring settings, made via the dialog or via SetIgorOption, are saved to preferences and used for future sessions.
Procedure Window Preferences​
The procedure window preferences affect the creation of new procedure windows. This includes the creation of auxiliary procedure windows and the initialization of the built-in procedure window that occurs when you create a new experiment.
To set procedure preferences, set the attributes of any procedure window and then choose Procedure→Capture Procedure Prefs.
To determine what the preference settings are you must create a new procedure window and examine its settings.
Preferences are stored in the Igor Preferences file. See Preferences for further information on preferences.
Double and Triple-Clicking​
Double-clicking a word conventionally selects the entire word. Igor extends this idea a bit. In addition to supporting double-clicking, if you triple-click in a line of text, it selects the entire line. If you drag after triple-clicking, it extends the selection an entire line at a time.
Matching Characters​
Igor includes a handy feature to help you check parenthesized expressions. If you double-click a parenthesis, Igor tries to find a matching parenthesis on the same line of text. If it succeeds, it selects all of the text between the parentheses. If it fails, it beeps. Consider the command
wave1 = exp(log(x)))
If you double-clicked on the first parenthesis, Igor would select "log(x)". If you double-clicked on the last parenthesis, Igor would beep because there is no matching parenthesis.
If you double-click in-between adjacent parentheses Igor considers this a click on the outside parenthesis.
Igor does matching if you double-click the following characters:
Left and right parentheses(xxx)
Left and right brackets[xxx]
Left and right braces{xxx}
Plain single quotes'xxx'
Plain double quotes"xxx"
Code Comments​
The Edit menu for procedures contains two items, Commentize and Decommentize, to help you edit and debug your procedure code when you want to comment out large blocks of code, and later, to remove these comments. Commentize inserts comment symbol at the start of each selected line of text. Decommentize deletes any comment symbols found at beginning of each selected line of text.
Code Marker Comments​
You can enter specially-formatted comments in procedure files to mark sections of code and later return to those comments using the Code Markers popup menu in the procedure window's navigation bar.
The navigation bar is visible if Show Navigation Bar is checked in the Editing Behavior tab of the Text Editing section of the Miscellaneous Settings dialog. The Code Markers popup menu appears on the left side of the navigation bar and looks like this: .
To get a sense of the purpose of code markers, we will look at the "HDF5 Browser.ipf" procedure file. It is an independent module so you must first execute this:
SetIgorOption IndependentModuleDev=1 // Enable editing of independent modules
Choose Windows→Procedure Windows→HDF5 Browser.ipf
Click the code markers popup menu and note the list of sections in the file such as "Utility Routines", and "Fill List Routines".
Choose Utility Routines from the popup menu. Igor displays the following line:
// *** Utility Routines ***
That line contains a code marker comment.
The format of a code marker comment is:
// *** <code marker text> ***
The code marker text, which appears in the code marker popup menu, is everthing after "// *** " and before " ***".
The code marker comment must be flush left with no spaces, tabs, or any other text before "// *** ".
You can insert a code marker comment manually or by clicking the code markers popup menu and choosing "Insert Code Marker Comment". You cannot insert a code marker comment if the procedure window is write protected or is open for read only.
Aligning Comments​
You can align comments introduced by "//" in a procedure window by selecting text and choosing Edit→Align Comments. This aligns subsequent comments with the first comment in the selected text. This feature is available for procedure windows only, not for notebooks.
Aligning comments requires that the procedure window use the spaces mode of defining default tabs. To ensure this, when you choose Edit→Align Comments, Igor adds a DefaultTab pragma to the procedure window if it is not already there. See The DefaultTab Pragma For Procedure Files for details about this pragma. The DefaultTab pragma is ignored by versions of Igor prior to 9.00 so comments that you align using this technique will not appear aligned in earlier versions.
Aligning comments also requires that the procedure window use a monospace font. It is up to you to make sure that this is the case. The factory default font for procedure windows, Lucida Console, is monospace font.
When you choose Edit→Align Comments, Igor finds the first selected line containing a comment (introduced by "//"). It then works on each subsequent selected line and attempts to align comments by inserting or removing tabs. During this process, Igor removes spaces that appear between the end of the line's active code and the comment.
Comments that are flush left are left unchanged as they typically appear above function definitions and are already positioned as desired.
By default, other pure comment lines (lines with nothing before the comment symbol except for spaces and tabs) are also left unchanged unless:
  • The section consists entirely of pure comment lines
  • You press the Alt key while choosing Edit→Align Comments to override the default behavior
In some cases, exact alignment is not possible. For example, if the active code of the second selected line extends paste the comment in the first selected line, removing all tabs from the second selected line does not achieve alignment. In such cases, Igor does the best it can.
Procedure File Text Encodings​
Igor uses UTF-8, a form of Unicode, internally. Prior to Igor 7, Igor used non-Unicode text encodings such as MacRoman, Windows-1252 and Shift JIS.
All new procedure files should use UTF-8 text encoding. When you create a new procedure file using Windows→New→Procedure, Igor automatically uses UTF-8.
Igor must convert from the old text encodings to Unicode when opening old files. It is not always possible to get this conversion right. You may get incorrect characters or receive errors when opening files containing non-ASCII text.
For a discussion of these issues, see Text Encodings and Plain Text File Text Encodings.
Shortcuts for Procedure Window​
See Procedure Window Shortcuts
