What's Changed Since Igor Pro 10.00?
This file describes significant changes made to Igor Pro and supporting files since the initial release of Igor Pro 10.00. If WaveMetrics has told you that an issue you reported has been resolved for the next version, it will be included even if it is not listed below. Here are the updates in reverse chronological order:
- XXX YY, 2026: Update 10.04B01
- June 16, 2026: Update 10.03
- May 13, 2026: Update 10.02
- April 29, 2026: Update 10.01
- April 22, 2026: Update 10.01B01
- October 15, 2025: Release 10.00. See What's New in Igor Pro 10? for changes since Igor Pro 9.
Update 10.04B01
Igor Application
New Features
Added /D flag to PolygonOp to create double precision output waves.
? : works with string values, not just numeric values:
String str = (num > 0) ? "something" : "nothing" -
Performance when displaying large images has been significantly improved, especially when logarithmic color scaling is enabled, resulting in much more responsive window resizing. Actual performance gains will vary depending on your hardware and image size. For example, on a 64 GB RAM PC displaying a 14,000 × 4,000 floating-point wave, resizing the window is now approximately 5-6x faster.
An improved algorithm for drawing line graphs is presented as an experimental feature, which can be enabled or disabled in
Misc. Settings > Experimental Features. Enabling it produces significantly faster drawing of simple line graphs than the legacy renderer with much higher quality output, especially when using transparency, thicker lines widths, or data with lots of noise. See the following benchmark comparison for graph updates with a 1000 point sine wave and a 1000 point wave of pure noise:
Improved performance for statement completion and help templates.
Tab labels now respect escape characters and render correctly for multi-line labels.
Changed Behavior
- TBD
Bug Fixes
- Fixed a rounding error in ImageInterpolate when using the Affine2D keyword that was causing output wave dimensions to be off-by-one.
Procedures
The Global Fit package (Analysis🠖Global Fit) now supports fitting with errors in the independent variable (X) as well as the dependent variable (Y), using the same Errors in Variables: Orthogonal Distance Regression machinery available in the Curve Fitting dialog. Assign an X Weight wave for a data set on the Data Weighting sub-panel to enable it. This release also includes several accompanying bug fixes: sub-panels are now reliably closed along with the main panel, and a missing weight or mask wave now aborts the fit with a clear error instead of proceeding silently.
Multipeak Fitting.ipf - Fixed several issues in the Post-Collision Interaction (PCI) peak shapes: PCI Threshold no longer returns zero at x = 0, PCI Threshold now automatically switches to the PCI Approximation shape instead of producing invalid results when an unsupported asymmetry value is encountered, and a sign error in the initial-guess calculation was fixed. The PCI Threshold (Strict) shape's polarization-dependent asymmetry factor also had a sign and ratio error in its high-excess-energy branch, causing a discontinuity in the peak shape at the boundary between the two energy branches instead of matching smoothly. Added a new "2nd Electron" derived parameter reporting the calculated partner-electron energy for the PCI peak shapes.
PeakFunctions2.ipf - Fixed several bugs affecting the reported ± uncertainty of peak coefficients and derived values in Multipeak Fitting and Curve Fitting (the fitted values themselves were not affected): the ExpConvExp peak's Location uncertainty omitted the contribution from the peak's own position parameter, and had a sign error in its degenerate-width branch; the Doniach-Sunjic peak's Location uncertainty applied a sign factor to the wrong pair of cross terms; the GaussConvExp (EMG) and LorentzianHeight peaks' Area uncertainty was scaled using the peak amplitude instead of the peak area; the LogNormal peak's Area and FWHM uncertainties erroneously squared the covariance terms, inflating them; the Voigt and VoigtArea peaks' FWHM uncertainty forced a covariance term to be positive instead of preserving its true sign; and the Voigt and VoigtArea peaks' Amplitude uncertainty omitted a sign factor for the GaussFWHM and LorentzFWHM parameters, which the amplitude formula uses only via absolute value, producing an incorrectly signed propagated error whenever either coefficient was negative.
PeakFunctions2.ipf - Fixed a bug where switching a peak's fit function to Voigt in Multipeak Fitting left the width and height fields blank (NaN) instead of populating them from the existing coefficients.
PeakFunctions2.ipf - Improved numerical instability in large Voigt shapes by replacing a piece of the shape expression with a better built-in Igor expression.
erfc(shape)*exp(shape^2)was changed toerfcx(shape). -
Multipeak Fitting.ipf - The Total Area uncertainty reported when simultaneously fitting multiple peaks now accounts for the covariance between peaks, instead of assuming each peak's contribution is independent.
Global Fit 2.ipf - Corrected the displayed Voigt fit function equation so that it matches the formula actually used by the fit; the fit results themselves were not affected.
WMFitFunctions.ipf - Fixed the built-in DoG (Difference of Gaussians) fit function's surround term, which diverged for points far from the peak center instead of decaying to zero.
WMBatchCurveFitResults.ipf - Fixed the nearest-point search used when displaying Batch Curve Fitting results, which applied an extra square root to only one of its two axis terms, distorting the distance metric.
FilterDialog.ipf - Fixed the "dB min -50" scaling option in the Filter Design Laboratory's frequency response display, which reported magnitudes 2.5 times too large.
Varimax.ipf - Fixed a sign-flip bug and a bug where communalities were normalized along the wrong axis, either of which could produce incorrect Varimax-rotated factors.
fuzzyClasses.ipf - Fixed a bug where two of the four fuzzy membership terms used each other's variance value, which could produce membership values that do not sum to 1.
Bivariate Histogram 2.ipf - Fixed BiHistWave() so that points falling below the histogram's X or Y range are excluded instead of being written into an incorrect bin.
Log Histogram.ipf - Fixed a bug where a value falling exactly at (or beyond) the last bin's upper edge was written one element past the end of the destination wave instead of being excluded.
leastSquaresEstimate.ipf - Fixed a bug that caused the function to read one wave element past its final computed estimate instead of returning that estimate.
Examples
- TBD
Update 10.03
Igor Application
New Features
The igorpro.fn submodule now supports calling Igor user functions defined in independent or regular modules.
For the independent module function
Analysis#processData()defined in Igor:#pragma independentModule = Analysisfunction processData()...return resultend# In Python, call the 'processData' function in the 'Analysis' independent moduleresult = igorpro.fn.analysis.processData() -
The prefix and postfix increment (++) and decrement (--) operators can now be applied to global variable references in Igor procedure code. For example:
Function test()NVAR globalNumber = root:myGlobalVarglobalNumber = 10// Postfix incrementVariable result = globalNumber++ // result = 10; globalNumber = 11// Prefix decrementresult = --globalNumber // result = 9; globalNumber = 9End -
Added a key binding to temporarily override snapping to drawing guides. Hold down Caps Lock while dragging an object to suspend snap-to-guide.
Changed Behavior
Improved ImageThreshold Fuzzy threshold methods (/M=4 and /M=5) to provide better threshold values.
The Find in All Windows command now uses the text under the cursor as the initial search string, matching the behavior of the regular Find command.
Bug Fixes
Fixed a bug in MLLoadWave where the operation's output variables where not set correctly when run from a user function.
Fixed a crash that could occur when drawing certain TIFF images (1 bit per pixel with LZW compression) in a page layout.
Fixed several problems interacting with draw object handles that extend beyond the page boundary in a page layout. Resizing and moving with those handles, cursor changes, and right-click contextual menus now work in the margin area. This was also broken in Igor Pro 9.
Fixed incorrect handle highlighting (and a crash) when changing the layout expansion while drawing or editing polygons and Beziers in a page layout.
Fixed a spurious compile error that occurred when a structure variable expression was combined with another expression.
Fixed a spurious compile error involving a FUNCREF and a global string variable that have the same name.
Fixed a bug in SplitWave when splitting a wave-reference wave or a data folder-reference wave (a wave whose elements are WAVE or DFREF references). Only the first output wave received the correct references; the second and subsequent output waves had their references written to the wrong positions, so they contained incorrect or missing references. Numeric and text waves were not affected.
Fixed a crash that could occur when free data folders stored in a thread queue were prematurely disposed.
Fixed a bug in Histogram where the square-root-of-counts destination wave specified with /N=destWave was created with the wrong name and as single precision instead of double precision.
KMeans now sets the documented V_flag output variable.
Fixed a bug in FindValue where the /RMD range was limited incorrectly for complex waves.
Fixed a bug in FindDuplicates that produced incorrect results for complex waves when the tolerance was zero.
Fixed a bug in ImageTransform where input waves used by the putRow and putCol keywords were not protected and could be overwritten when /DEST was used.
Improved the error message reported when an unknown or inappropriate name is used where a number is expected. The message is now clearer instead of always reporting "expected number".
Procedures
Multipeak Fitting.ipf - The Multipeak Fit GUI now computes derived peak values (such as FWHM and peak area) for each peak after a fit. The results are stored in new "Peak N CoefsDER" waves alongside the existing peak coefficient waves.
Multipeak Fitting.ipf - The Estimate Now button now bases its estimates on the currently visible graph range, so zooming in or out before clicking Estimate Now changes the result. Previously the estimate ignored the displayed range.
Multipeak Fitting.ipf - Fixed a regression where finding peaks in the residuals could report many spurious peaks when the peaks are negative. This was visible in example 3 of the Multipeak Fit Demo experiment.
Split Axis.ipf - The Split Axis package now copies error bars onto the split traces.
Update 10.02
Igor Application
New Features
PlaySound added /PAUS and /GO flags for pausing and resuming asynchronous sound playback.
FUNCREF can now be properly passed by reference and returned from functions.
Changed Behavior
The
/UNATTENDEDcommand line flag now skips the license activation dialog. -
In 10.01, bitwise operators (&, |, and %^) returned incorrect large negative values when either operand was
NaN. Bitwise operators are now defined to treatNaN,Inf, and-Infoperands as 0, matching the behavior in Igor 9 and 10.00.
Bug Fixes
Fixed a bug (introduced in 10.01) where layout draw objects selected a phantom object after drawing.
FuncFit and FuncFitMD now support user-defined fit functions with complex independent variables in multidimensional curve fitting.
Fixed a Qt library bug that resulted in a crash/exception during startup on machines running old versions of Windows 10.
Fixed a crash in FuncFit when the fit function had no parameters.
Fixed line continuation anomalies in the compiler.
Fixed various Ctrl+F (Find), Ctrl+R (Replace), and Ctrl+G (Go To Line) bugs in procedure windows, the command window, and notebooks.
Update 10.01
All changes from Update 10.01B01 as well as the following changes:
Igor Application
Bug Fixes
Fixed a crash in ConvexHull.
Fixed a problem that caused incorrect rendering when exporting a cropped multipage layout as PDF. Previously the first page was rendered correctly but the rest of the pages might have been rendered with the wrong aspect ratio and/or bounding box.
Update 10.01B01
Igor Application
New Features
Added a German language translation of the user interface (menus, dialogs, etc. but not documentation). We used AI for the translation (with partial human review) so there may be mistakes. Open the Miscellaneous Settings dialog (Misc🠖Miscellaneous Settings menu item) and select the Environment category to select a language. If your OS language is German Igor should ask you if you want to use the German language when it starts. Igor will remember your selection.
We might use a similar process for additional languages. If you are interested in helping translate Igor, please see our post at https://www.wavemetrics.com/forum/general/help-us-translate-igor-pro for additional information.
Documentation for Igor Pro is now available online at https://docs.wavemetrics.com.
PlaySound entirely rewritten to achieve gap-less playback of queued sounds. Added /STOP flag to stop any asynchronously playing sounds.
Python 3.14 is now supported in Igor Pro 10.01.
Our support for Python 3.14 is currently limited to the 'standard' installation of Python 3.14, not the free-threaded installation.
Added the igorpro.fn submodule for Python. This submodule allows users to directly call — and return values from — built-in, external, and user-defined Igor functions.
For example, to call Igor's built-in SortList function, you can now write:
# Descending sort. 'sorted' will hold: 'a;c;d;e;g;x;'sorted = igorpro.fn.sortlist('x;c;e;g;d;a', ';', 1)igorpro.fnsupports returning real and complex numbers, strings, wave references, and data folder references from Igor functions. -
Using the Igor64.exe command line flag
/START=3now prints startup information to standard output (stdout). This can be useful if you are running Igor via some automated process. -
MatrixOP /KCLS flag has been extended to support the third dimension.
Improved performance of all-at-once threadsafe curve fitting by approximately 50%. The unperturbed model calculation is now run inside the parallel multithreading loop.
Added a flag (
/CPAD) to ImageTransform padImage that supports symmetric padding around the image in either mirroring the edge data or repeating the last pixel values. -
Gizmo, Igor's 3D graphing tool, now supports rendering of exported graphics and page layout images when the Gizmo window is hidden. Previously, a Gizmo page layout object displayed a blank box with the message, "Cannot draw a hidden Gizmo". See Gizmo Overview to learn about Gizmo.
Changed Behavior
- The
_labels_keyword used in Display, AppendToGraph, and ReplaceWave commands is no longer translated in localized versions of Igor. Previously, Japanese Igor translated this keyword to_ラベル_, which caused errors when experiments or procedure files were shared between different language versions. Commands now always use_labels_regardless of language. For backward compatibility, Igor still accepts_ラベル_when parsing commands, but always generates_labels_when creating commands.
Experiments or procedure files created with Igor Pro 10.01 or later that use the _labels_ keyword will cause errors when opened with Japanese Igor Pro 8 through 10.00, since those versions only recognized the translated _ラベル_ keyword. When opening an experiment file, a dialog will appear allowing you to edit the failed command- simply replace _labels_ with _ラベル_ to resolve the error.
Improved error checking for inputs to the IntegrateODE operation. This includes checking numeric inputs for proper range, forbidding
NaNandInfvalues, and checking for missing waves or waves with incorrect type or size. This could potentially cause errors in "working" code, but the errors flagged would have caused incorrect behavior that could be hard to debug. -
Bitwise operators (|, &, ~, and %^) no longer convert their operands to unsigned integers with truncation. They now convert their operands to signed integers, so that signed operands produce the expected result.
#pragma independentModule=ProcGlobalis now a compilation error. This was never valid but was previously silently accepted. -
Igor now checks the Python version before initialization and gives a clear error message if the version is unsupported.
HDF5SaveGroup saves waves more efficiently when data folders contain many waves. This also applies to saving a packed HDF5 experiment.
Bug Fixes
Fixed a bug in the Text Marker dialog that caused a mismatch between the text anchor point widget and the anchor point in the generated command.
Improved rendering of EMF pictures in notebooks and help files.
Control position and sizes accept floating point values.
Controls are more accurately positioned and sized when control panel expansion is other than a multiple of 100%.
XOPs can now be used as fit functions. Previous incorrect behavior was that any fit using a non-threadsafe external fit function would result in a singular matrix error. This has been fixed. Threadsafe external fit functions were not affected by this bug and continue to execute normally.
Fixed a bug that caused layouts to be the wrong size and position when printed.
Fixed a bug that could result in incorrect triggering of trace drag in a graph subwindow if you clicked first in the graph subwindow and then quickly clicked and held in some other area of the window containing that graph subwindow.
Fixed a bug that caused too many calls to a window hook function for Resize events.
Fixed a bug in the FindPeak operation that caused a crash when finding peaks in a wave with more than a million data points. The fix both prevents the crash and improves performance on these large waves by a factor as large as 40.
Fixed a bug that could prevent drawing of graph draw objects that use axis coordinates.
Fixed a bug that incorrectly limited dragging of Layout Guides when a subwindow was activated.
Fixed a potential crash if you killed a wave while in Edit Wave mode in a graph window.
Fixed a bug that caused custom colors added in the Select Color dialog (what you get when you click the Other... button in a color picker) to not be saved and restored across Igor sessions.
Fixed a bug where Python code completion results were not sorted.
Fixed a bug where collections of Python booleans (lists, arrays, tuples) could not be returned to Igor.
importcould not find modules in the current working directory. -
Fixed a bug where the Python console window was not shown and raised when selecting Open Console from the Python menu.
Fixed Python console docking and undocking coordinate issues on multi-monitor setups.
Fixed a bug where the code completion popup did not offer suggestions for module-qualified functions (e.g.,
myModule#funcName). Also improved completion within independent modules to offer functions from the entire module namespace, not just the current file. -
Fixed a bug in ImageRegistration that caused a memory issue when processing stacks.
Fixed a crash in WaveStats and incorrect wave creation in MatrixOP related to the /KCLS flag with certain dimension configurations.
Fixed bugs in ImageEdgeDetection boundary processing.
Fixed a bug where the ImageMorphology /S flag was incorrectly changed to /H. The documented /S flag is now used.
Fixed a bug in DuplicateDataFolder that could corrupt a pre-existing local string variable when it shared an internal pointer with a global string being overwritten.
Fixed a bug where MoveWave incorrectly cleared the contents of wave-reference waves when moving free waves through a free data folder.
Fixed a bug where ReorderTraces with an invalid trace name could delete traces from the graph before reporting the error.
Fixed a bug in the ReorderTraces and ReorderImages dialog that caused it to fail when the same wave appeared in a graph more than once.
Fixed a bug where IntegrateODE programmed stop (derivative function returning 1) did not take effect immediately and could delay for a long time with small internal step sizes.
Fixed a bug in IntegrateODE using the BDF method where an error weighting wave could cause incorrect results or errors due to uninitialized memory.
Fixed a bug where string functions such as TrimString truncated strings at embedded null bytes instead of preserving the full string content.
Fixed a bug where RemoveFromTable incorrectly applied column type restrictions that should only apply to AppendToTable.
Fixed a crash when dragging a subwindow resize handle.
Fixed a crash when using the graph contextual menu in certain configurations.
Fixed a potential crash when XOP functions use structs with threadsafe pointers. Also fixed incorrect complex return values from external functions used by SumSeries.
Fixed a potential crash when checking structs for external curve fitting functions.
Fixed a crash during mouse release on exterior subwindows when the window is destroyed during event handling.
Fixed a bug where tags attached to hidden traces or images were not hidden.
Fixed Gizmo axis labels being clipped at the top.
Fixed a bug where Gizmo surface objects with
NaN-containing matrix waves did not draw when using constant color. -
Fixed a bug where free axes positioned relative to perpendicular axes did not reserve room for axis labels during graph recreation.
Fixed a bug where column grid lines in table subwindows within layouts were not drawing correctly at certain display scalings.
Fixed a bug where table subwindow column widths shifted incorrectly during resolution changes in layouts.
Fixed a bug where table subwindows in layouts were continuously repainting, causing excessive drawing and performance issues.
Fixed a bug where right-clicking a table subwindow did not activate it before showing the contextual menu.
Fixed several issues with Find (Ctrl+F), Replace (Ctrl+R), and Go To Line (Ctrl+G) keyboard shortcuts in procedure windows, the command window, and plain text edit fields. The cursor now correctly focuses on the appropriate text field when switching between Find and Replace modes.
Fixed a bug where the STFT dialog "From Target" toggle did not work correctly.
Fixed a bug where 8-bit AIFF and AIFC audio files were loaded with corrupted (unsigned instead of signed) sample data.
Fixed a bug where DoIgorMenu did not update associated graphs while a dialog was open.
Fixed duplicate ruler IDs in notebooks that caused rulers to switch unexpectedly when adjusted.
Fixed a bug where the compiler gave a confusing error instead of "Expected a wave reference" in certain scenarios.
Fixed inconsistent error messages in ControlBar between compiled and interpreted code paths.
CurveFit now accepts wave subranges when using an X wave. Previously, subranges were rejected even when the subrange size matched the X wave size. This has been a bug for decades.
Fixed a bug where dashed lines with
NaNcoordinates could cause rendering issues. -
Fixed a bug in the area function where the trapezoidal end-point correction was discarded, producing incorrect results. The faverage function was also affected.
Fixed bugs in MatrixOP
crossCovarandbinVar.crossCovarwas squaring the wrong input's data, andbinVarwas summing deviations instead of squared deviations.
Procedures
- IFDL.ipf - Resized the IFDL panel to show entire title.
Examples
All Controls Demo.pxp - Modernized for Igor 10.
Resize Panel and List Demo.pxp - explains 3 different ways to resize controls in a panel:
- custom window hook
- generalized window hook with ResizeControls.ipf
- user guides introduced in Igor 10
